Cheap "high voltage" esc Quest
snellemin
2 KiloWatt RACER
snellemin's Avatar
Cheap "high voltage" esc Quest - 01.18.2008, 01:00 AM
I think I found for an affordable "high voltage" programmable ESC. I got it yesterday and it worked great with 3s1p A123. When I doubled the voltage it blew the stock tiny caps. Brought it to work today and added some better caps. I benchtested it with 6s1p A123 and it worked great. I'll use it on Sunday and see what kind of abuse it can take during dragracing.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
01.18.2008, 01:11 AM
Well where did you find it, what are the specs? I want to know!
dezfan
01.18.2008, 01:21 AM
Ditto, sounds interesting!
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.18.2008, 01:37 AM
huh, Fleabay.
up to 25V with external BEC, 18 volts nominal.
comes with programmer..has lcd screen. No laptop needed.
120A continious and 150A peak
getting it to sync with remote was tricky
comes with 3300 kv motor
took almost 2 weeks to get here.
johnrobholmes
johnrobholmes's Avatar
01.18.2008, 02:15 AM
Where would one procure some of that nice shrinkwrap?
01.18.2008, 04:22 AM
Maxamps has shrinkwrap of all sizes: http://www.maxamps.com/products.php?cat=71
tom255
tom255's Avatar
01.18.2008, 05:15 AM
Is it this ESC?
http://cgi.ebay.com/1-10-Brushless-C...QQcmdZViewItem
I allmost bought this but no information abot this ESC hold me back, i think that its overrated and not so good quality. Blown Caps shows that. Can you tell something about fets?
But tell us how its perform? Trigger reaction? Lets say is it possible to correct car fly trajectory from jump with throttle without delays? Its realy imprtant becouse i race only dont do speedruns. And also tell about BRAKS are they good? strong and smooth?
johnrobholmes
01.18.2008, 05:31 AM
I think I already have that same combo coming to me as well. I know the ESC is on the way, I don't remember if I got the motor too.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
01.18.2008, 07:30 AM
..... I actually bought this last week for one of my boats. I'm going to run 2s and 3s on a 24" cat that I have, but now I may have to drop it in a truck first.
snellemin,
I'm not too surprised you blew the stock caps on 6s a123's. I read your write up on rcu, and know your were pushing the limits. Hey, would you be willing to set up my esc with some 35a caps like yours? If so, send me a pm.
rcm xt8
rcm xb8
rcm crt.5
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.18.2008, 11:19 AM
That is the ESC man, which got more expensive. I used 4.5" wide thick heatshrink and soldered on 3x 330uF 35Volt caps.
To enable the ESC, you have to put in it reverse after the first beep. You'll hear another beep, which tell you that the ESC is enabled.
sikeston34m
sikeston34m's Avatar
01.18.2008, 12:05 PM
What were the ratings on the stock caps that came with it?
Hmmmm.........looks interesting.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.18.2008, 12:11 PM
The stock ones were two tiny 220uF 35V caps.
sikeston34m
01.18.2008, 12:26 PM
I've had really good success using the Novak HV capacitor. I've ran it on 6S without any issues and it doesn't get warm or anything.
http://www3.towerhobbies.com/cgi-bin...?&I=LXKKN3&P=7
It produces ALOT of zap.
sikeston34m
01.18.2008, 12:33 PM
This ESC looks like a good candidate for a project I'm planning.
I want an ESC setup that will run dual brushless motors in a boat.
It looks like all of the FET's are on the same side of this power board.
I need to find some sort of cooling plate made of either aluminum or copper that allows me to circulate water through it. It needs to be approximately the same size as the fet area on this board.
Then secure one ESC to each side of the cooling plate with thermal heat sink compound. Jumper the power wires, jumper the receiver harness (opto-mod) of course. Then heat shrink the entire thing together.
The end result would be a compact ESC unit that would run cool. It would have two sets of motor leads coming out. One set of battery power leads, and one receiver hook up.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.18.2008, 01:12 PM
Oooooo. Looks like that may be just what the doctor ordered!
It's actually made for cars! *faints*
Snelle, hopefully it survives the weekend. If so, I'm putting one on order to run my emaxx. However, that seller doesn't have any for sale now...
