01.23.2008, 01:57 AM
Originally Posted by ClodMaxx View Post
how funny would that be... if castle came out with another firmware update where the controllers would make artificial weed wacker noises when the throttle is used...
We could call it a SNN module (simulated nitro noise). They could also develop a pressurized container that automatically sprays the inside of the body and chassis with a sticky substance whenever the body is installed! Or a mercury switch that turns the esc off when you flip the car over. This would be great stuff, and would really help people with the changes from nitro to brushless.
gixxer
gixxer's Avatar
01.23.2008, 02:21 AM
sounds like I will have to download the new updates. not sure if I am brave enough to try a neu with the esc yet though.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
01.23.2008, 01:36 PM
does anyone else notice that their MM makes a beep every few seconds when the truck isn't moving? it never did that before. i didn't reprogram my MM's after the update, so i'll try to see if that fixes it. nothing happens that i need to worry about...it's just a little unnerving! i have 2 MM's on one truck and turn them on at different times, so both beep just out of sequence of each other.
Eflite Blade 400 heli on 3s
johnrobholmes
johnrobholmes's Avatar
01.23.2008, 02:12 PM
The beep is to remind you that your ESC is still turned on.
chilledoutuk
01.23.2008, 03:28 PM
I guessed as much.
I think its a good feature it reminds you to turn off the mamba max after a run protecting your battery's etc.
I like the way the new doo doo sound it makes when starting up slowely now it seems that once it gets to a certain rpm it changes to a new mode or at least that's what it sounds like.
HBRC
HBRC's Avatar
01.23.2008, 03:33 PM
seems a little smoother on startup on my Neu 1.5Y. hard to tell in the basement. I'll have to wait to get to the track for a real test.
It is smoother on my crawler with an outrunner. Still have to test on the rocks as well.
friggin winter. gotta wait for a thaw...
gixxer
gixxer's Avatar
01.23.2008, 06:49 PM
well I just downloaded it. tried my 8t out in the house with 5s and a 12xl feigao. so far all I notice is the annoying sound at low speed. guess I will have to wait for the woman to get home so I can try it outside (have to watch the little one).
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
01.23.2008, 09:11 PM
I just fried my MM. This stinks. I downloaded the new firmware and I just tried it again in my TC3. Plugged the 2S lipos and as soon as I turned the MM on, a few sparks came out.
Send it in. Doubtful it was the new software that did it, but who knows...we'll cover you. :) Include in the service request form that after you downloaded the new update the ESC sparked right after plugging in. We'll get you fixed up. Service request form and all pertinent information to send the ESC in are located on the support tab of our website.
Joe Ford
Product Specialist
lutach
lutach's Avatar
01.23.2008, 09:18 PM
It was strange, but the sparks happened after I turned the switch to the on position. Thanks for checking in Joe.
JeffEmbracedDC
JeffEmbracedDC's Avatar
01.23.2008, 09:45 PM
Joe, I want to thank you for the support you guys have given me on my castle products. You're always really fast with your warranty replacements. I own two MMs which I just updated and they run great, two 5700 motors, and I just ordered a CCBEC, Castle Link and a Sidewinder from the Castle site along with some bullets for my conversion project. I really like your products. Thanks again :)
-Jeff Jassky
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
pb4ugo
01.23.2008, 11:48 PM
Originally Posted by gixxer View Post
well I just downloaded it. tried my 8t out in the house with 5s and a 12xl feigao. so far all I notice is the annoying sound at low speed. guess I will have to wait for the women to get home so I can try it outside (have to watch the little one).
And I have a hard enough time with one!
01.24.2008, 12:11 AM
Ok, just did the downlaod onto the mm in mt ext crt.5. I run a 3s 4200 lipo and a plett maximum. It does start the 4 pole motor better, and the esc seems to run cooler too. I also seem to have better runtime, like 3-5 minutes. Good stuff, can't wait to try thiws update with a aquacraft 6 pole motor in my new emaxx. We will see if it can start that motor, it is impossible to turn by hand! I also have a novak 6.5 that I eill try out in my xxx-cr buggy. Great revision for the best low cost esc around!
chilledoutuk
01.24.2008, 07:52 AM
you have a plett max in a crt .5?
01.24.2008, 11:21 AM
Yep, makes for a good 3s motor (3100kv) and it never gets much more than slightly warm.
DrKnow65
DrKnow65's Avatar
01.24.2008, 11:26 AM
Of course it doesn't get warm, there's no pinion gear!!! hahahaha
