spring question
DickyT
spring question - 01.24.2008, 10:07 AM
I am about 85% done building my e-revo and thought I was good with springs. as a roller it sat so high I was worried that it would be too stiff. After installing my neu 1515 and adding a 400g weight to the battery tray to simulate close to rtr weight it almost bottoms out just sitting on the floor, even with the collars tightened all the way down.
I have the teflon coated GTR's, 60wt in rear, 50wt in front, white springs on front and green on the rear.
I do not want to spend a fortune on springs trying to figure this out. What are some of your guys recommendations for a high speed high flying basher?
DickyT
01.24.2008, 10:47 AM
I forgot to add, I am thing about moving the greens to the front and getting gold or tans for the rear. would this be adequate?
Just go Play
Just go Play's Avatar
01.24.2008, 11:01 AM
I had the same problem when I built my e-revo also. I was using like the gold and tan springs (I think) which was ok.
I found that the revo springs all seemed to be like 1/4 - 5/16 short and required screwing the preload down 25% - 50% just to remove any play. I don't know if this normal or not but I found it annoying so I ended up using some firm and X firm springs from a set of powerstrokes. The springs are just long enough to fit snug with no preload required and are working good for bashing.
You may find that you'll want to run a little heavier rear then whatever the recommended setup is since you weight is carried a bit more on that end.
Just go Play
01.24.2008, 11:05 AM
Yes that would be much closer but if you plan on hitting larger jumps you'll likely want something heavier then the green up front. It will really depend on how/where your going to be running the truck.
