The OFFICAL RC-MONSTER extended crt.5 thread.
rchippie
rchippie's Avatar
The OFFICAL RC-MONSTER extended crt.5 thread. - 01.30.2008, 09:27 PM
Hi everybody sinice there are more than a few of us here with the extended crt.5, i thought it would be helpfull if we had just one thread for setups & tips or anything reguarding the kit instead of everone having there own thread. I would like to know what springs everyone is using ?. I only have the original gray springs that came with the jammin kit. I orderded bowties & a proline CP t4 body for mine. My power system will be
ESC MM
motor 7s 5070kv
gear 12/46 going to try 13/46
lipo maxamp's 2s2p 8000's for now
radio M8 with a novak switch module & xxl reciver
servo hitec 5955
REAL MEN RUN BRUSHLESS
BlackedOutREVO
01.30.2008, 09:50 PM
I just run a orion 10.5, with no esc now...
A TrakPower 2s
Spektrum DX2.0
servo, Futaba S9550
Im using the stock set up, just with 40 wt oil in the rear, and 7K oil in the center
entjoles
01.30.2008, 09:58 PM
i am using...........
rc-monster chassis
proline 30 series bowties
jconcepts gt2 body(to long imo)
mm
9l
3s maxamps 5k
15/46
med. springs(blue), will try heavy springs(white)
rchippie
rchippie's Avatar
01.30.2008, 10:26 PM
rc-monster chassis
mm
9l
3s maxamps 5k
15/46
how do you like the blue springs compared to the stock gray springs ?. the gray's feel a little soft in my opinion with the 8000 lipo im using.
What weight shock oil are you guys using ?. This is my current setup.
http://www.jamminproducts.com/CRTset...5JHreddeer.pdf
rschoi_75
Certified Spaceball
rschoi_75's Avatar
01.30.2008, 10:33 PM
Stock chassis w/ crowd pleaser body
Proline Dirtworks truck tires
MM
Lehner Basic XL 4200
Neu Energy 2s 5000mah
16/46
White springs all around (I like them a better than the blues)
cnc knuckles, hubs, and chassis braces.
rcm xt8
rcm xb8
rcm crt.5
01.30.2008, 10:35 PM
Ok, RCM ext chassis
Plett maximum (3100kv)
3s 4200 maxamps lipo (3s2p 2100 cells)
MM
13/46 gearing
Proline bowties on traxxas front rims
Proline crow pleazer for xxx-nt body
entjoles
01.30.2008, 10:37 PM
so far i think they are ok, have not jumped it much in ext. form though, so the white springs may be better for heavy bashing
rchippie
rchippie's Avatar
01.30.2008, 10:42 PM
I think with the extra weight of the extended chassis & my 8000 lipo & the larger wheels & tires im going to get at least the blue springs.
02.01.2008, 11:51 PM
Hi,
Well I'm using an OFNA extended chassis... Really love how this thing goes on 3s 5000/ 7L with the 2.8 annaconda's. 16/46 gearing
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 16
Total Voltage: 11.1
Motor KV: 3511
Tire Diameter (inches): 3.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0059
Spur/Pinion Ratio: 2.88 : 1
Total Ratio: 9.34375 : 1
Tire Circumference (inches): 11.78 inches (299.24mm)
Total Motor Speed: 38972.1 RPM
Vehicle Speed: 46.53 MPH (74.75km/h)
Effective Speed Rate: 4.19mph/V (6.73kmh/V)
Effective KV Value: 3511
I've done some work on her this week in re-doing the esc mount, battery tray and fixing up the MM - extra 2700uf cap and 5.5mm motor connectors.
Also fixed the front body mounts with some traxxas ones...
For a treat I also put some new shoes on her tonight to get a bit more offroad traction - jato rear victory's all round...
The wiring only looks like a mess ATM as I have the eagletree installed with the esc temp and brushless rpm sensor.
I'll get some logs up over the w/e if the weather stays ok...
PS the body is my first non-one color wonder... so nothing special
02.02.2008, 02:52 AM
Looks familiar, Is that my old crt.5?
02.02.2008, 09:55 AM
Well the front and rear are the same... All of the middle and shoes are new :)
GO-RIDE.com
02.04.2008, 04:24 PM
I don't remember my kit having 4 concave washers, but the 4 aluminum spacers are to make the battery posts taller if you run a bigger battery. Of course you will also need longer screws. My batt posts come loose from time to time, I wonder if the concave washers are to serve as a lock washer for the posts?
I'm planning on making a large post of all setups I've tried and am currently trying. But as for shocks I've been running the stock 50F / 35R, but with the single hole pistons. This is over damped, but I run a smoothish clay track with big jumps. The big jumps require a lot of damping.
I've had the best luck with blue srpings front and grey rear. The car handles good and does not flip often. With blues all the way around or whites F and blue R the car flipped a bit too often.
I started with the front swaybar removed and have since removed the rear too. This again cuts down on the car flipping. It may also let me run blue rear springs, but I have not tested this.
One other thing. 2.2 truck tires are nice on rough loose ground with smaller jumps, but on bigger jumps they are difficult to control. I'm talking 25' jumps out of a tight bowl corner. With the smaller stock tires the car is very controllable in the air with the brake or throttle. With the truck tires the car is good for back flips, but difficult to control precisely.
WHOA, WHAT HAPPENED TO THE POST I WAS RESPONDING TO? There was a new post asking what the extra spacers were for in the RCM extended chassis kit.
E-8ight - Tekin RX8 2000kv/4S
rchippie
rchippie's Avatar
02.04.2008, 04:32 PM
I found out what there for monster mike told me as for the post after mike told me what they were for i felt like a idiot & erased it .
rchippie
rchippie's Avatar
02.04.2008, 04:34 PM
Also when you make your setup post please try to keep them in this thread . It will make it a lot eaiser for everyone if there is only one thread about it .
GO-RIDE.com
02.04.2008, 05:57 PM
No problem...What are the concave washers for?
