Quark on 6S with Mega 6 pole
speedracer1129
Quark on 6S with Mega 6 pole - 03.14.2008, 09:14 PM
OK. I have just built an Inferno GT for a customer and I am having some huge problems!! Here is the setup:
- Quark 125
- Flight Power 6S2P 4350 EVO25
- Mega 22/30/1e 6pole
- 25/46 Gearing
First night out, 12 seconds into the run the controller blew up!!! Quark sent me another one within 4 days. Setup the new one. Now, on 4S test, it ran decent for the 5 minutes we tested it. Everything temped ok and the car did 69mph while spinning the tires the whole run. When we slapped the 6S, it thermalled almost immediately in the first pass!! It seems like there is a compatability issue with the Mega motor and the ESC.
SOOO...........
a: Anyone running this setup of motor/ESC successfully??
b: Has anyone ran a Feigao/Quark setup successfully as Quark told me to try another motor but I am afraid of blowing another controller or more......
03.14.2008, 09:20 PM
Your gearing is most likely overdrawing the esc. The quark is a solid 5s controller, but very load sensitive on 6s. So try gearing down. It should not have any issues with the 6 pole motor, the quarks can run just about anything.
bdebde
That's All Folks!
bdebde's Avatar
03.14.2008, 11:28 PM
6s is most likely the problem.
starscream
RC-Monster TQ
starscream's Avatar
03.15.2008, 01:53 AM
I agree with linc,
Wow, if you are doing 69mph on 4s and then add more voltage you've gotta be taxing the esc. By the sound of that, it doesn't suprise me that the Quark thermalled on 6s
Ha Ha
03.15.2008, 02:26 AM
Yeah, that car must be geared for about 100 on 6s. May want to drop the gearing down to about 70 mph top speed, 18t? pinion maybe?
speedracer1129
03.15.2008, 01:11 PM
Well, the car was built for speed only! THis is a purpose built car for a max of 5-6 passes and then shut it down. I am going to gear it down and see what happens. Funny thing, you would think it would run cooler with the higher voltage??
sikeston34m
sikeston34m's Avatar
03.15.2008, 01:36 PM
I have heard no mention of a BEC being used.
Are you using a BEC with this? Because if you're not, it's going to fry the internal bec very quickly.
The Quark 125 amp version is capable of alot. I've ran 6S on 2 of mine without any issues using multi-pole motors.
As far as heat issues go, you're alot better off to mount it to an aluminum surface, if you have one available. Coat the underside with thermal heat sink compound, then secure it with ties or something.
A fan doesn't hurt anything either, especially if you're going into that upper realm of it's ratings.
I hope this helps.
03.15.2008, 02:44 PM
Yep, I forgot to ask about the bec, use a ccbec if you can.
A fan and good heatsinking is a must, but it is good to test on lower gearing and them gear up until the equipment starts to overheat.
sikeston34m
03.15.2008, 02:56 PM
The Quark line of ESC's are not over rated. They will deliver the amperage they advertise.
The catch is the liniar Battery Eliminater Circuit they have built in, isn't capable of carrying the Receiver/Servo's when powered by more than 4S.
The internal BEC just creates soooooooo much heat. Even on 4S, by adding a Castle Creations BEC circuit, ESC temps will be reduced alot.
In other words, if you're NOT using an External BEC, the majority of the heat that you are seeing isn't necessarily coming from the Power FET's inside the speed controller. Most of the heat is coming from the internal BEC that just can't keep up.
The Castle Creations BEC is soo nice also. It gives you the option to adjust the amount of voltage supplied to the Receiver/Servos. I have mine set to 6.0 volts. This makes the Servo's stronger and faster than powering them by an ESC (5.0 volts).
Look in your Quark manual under "Opto-mod" for more information on using an external BEC.
sikeston34m
03.15.2008, 03:28 PM
I've been tempted to try one of the large 6 pole Mega Motors in an E maxx.
I wonder how it would do?
03.15.2008, 04:42 PM
Like the 22/50 series? Those look like beasts!
Maybe the 22/45?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.15.2008, 04:46 PM
The controller is thermalling so fast mainly because of the 6-pole motor. Think about it. If 2 poles = 6 pulses per revolution, then 6 poles = 18 pulses per revolution. The ESC is working 3 times harder than usual. Add higher gearing and maximum voltage and that's pretty hard on a controller. Do you have a fan you could use on it? I think 5s with a fan would work fine.
speedracer1129
03.15.2008, 05:36 PM
Sorry, Yes, I am running a CCBEC. I have heard rumors that the 6S rating is not a "comfortable" rating....which makes me wonder why they would rate it at that level?? I am running the same setup with a CC 5700 motor on 4S in a 1/10 and doing 95mph very reliably which further leads me to believe the whole 6S rating rumor!! I am going to the smallest gear I have which is a 22T as I am running the 2 Speed adaptor and using LST2 2nd gears to drive the 46T spur. If I see it gets better, than I will have to order some Mod1 pinions from Mike to continue testing. I have already blown 1 controller while running it in outrunner mode and Quark immediately sent me a replacement as they said it sounded like faulty programming. I am now running in inrunner mode and it is holding up fine, but still thermalling 10-15 seconds into the run on 6S. I will be getting my Eagletree this week so I will know for sure what is going on on the next test run!!
speedracer1129
03.15.2008, 05:40 PM
I would agree with you, but I can't due to the following. Mega recommends only CC ESC's and they have no issues running a CC ESC that was designed to run a 2 pole motor?!? This leads me to believe that the Quark programming has alot to do with it. Worst case scenario, the guys at CC could maybe speed up the MMM a little( ugh, ugh) and I will go that route. We will see....
03.15.2008, 06:34 PM
still...holding...breath...for...mamba...monster.. .maxx!
