Revracer
Revracer's Avatar
03.19.2008, 07:16 PM
man this is amazing. your amazing man. just another project to put on my lists.... really wish you could get a video up man
brushlessboy16
brushlessboy16's Avatar
03.20.2008, 09:10 AM
You should try a big Outrunner directly connected to the rear diff, find like a Big Axi like this
http://www3.towerhobbies.com/cgi-bin...?&I=LXPPY6&P=0
or for more power and less money go with this monster
http://www.hobbycity.com/hobbycity/s...idProduct=5139
Torque
Fast5sRevo88
Torque - 03.20.2008, 03:41 PM
I like the idea, but with direct drive would the Axi have enough torque? And holy horse hockey could it possibly handle that hobbycity motor?
brushlessboy16
03.20.2008, 06:25 PM
the axi might not have enuff ooommmphh..
but that hobbycity one, it should do fine in the baja, just make sure ur mount is strong enuff
lydiasdad
03.20.2008, 09:30 PM
The buggy itself is done. I would have to change it quit a bit to run that big motor. It is only 13 lbs rtr. I just need a better motor, and maybe more cells I did change the gearing to 20/66 and the speed is very nice, but the motor no likey. It got hot pretty quick. I'm not using a heat sink though. I will probably run this setup until the MMM comes out. I think I can fit four more cells to run 8s2p a123 with my mega 22/45/2. I would like to get 20 minutes runtime at about 40mph. Oh, I talked to one of my buddies and he has a camera so I should get a video next week.
Jbreddawg
Jbreddawg's Avatar
03.20.2008, 09:33 PM
Are you using 40 series rims in the front also ? Or just the back ?
lydiasdad
03.20.2008, 09:36 PM
just the rear
Revracer
Revracer's Avatar
03.22.2008, 05:50 PM
your saying your mega motor gets hot quickly? i just got a 22/30/1 for my revo. it weighs right around 8-9 lbs so how do you think that will do...? bluegrooveconcepts.com used the motor on a 16/36 gearing with 3s and it did great though. low temps and everything.
lydiasdad
03.22.2008, 10:49 PM
no, the 9xl is getting rather hot. I'm not running the mega yet.
video
lydiasdad
video - 03.28.2008, 12:22 AM
I got a short video today. It doesn't last very long as I blew the diff at the end of the run. I was driving pretty stupidly I switched to 20/66 gearing and am pretty happy with the speed, but I'm thinking of getting a kb45-10L. I had the data logger on this run and peaked at 1690 watts and 112 amps. I am running with an actual 5b tomorrow and I will get a better video of that. http://s283.photobucket.com/albums/k...t=DSCN6290.flv
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
03.28.2008, 12:57 AM
Awesome. Still needs more power though . Can't wait to see it compared to a real baja.
03.28.2008, 01:00 AM
The KB45 10l is a bad (good?!) motor, much more powerful than the feigao xl motors. I have not tested my xl kb motors yet, but they should be potent to say the least!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
03.28.2008, 01:06 AM
It's just annoying they aren't 5mm shaft and normal hole spacing.
03.28.2008, 01:21 AM
True, but I removed the front endbell and drilled/tapped m3 holes in a 25mm spacing. You could have the shaft turned down, or drill out a pinion. I make my own mounts for these motors, so that is not a big deal for me. They are well worth the hassle, considering the price.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.28.2008, 01:27 AM
That looks pretty sick... I hope that has enough ballz to beat the baja... a baja with 30.5cc engine is pretty fast and powerful... Hook us up with the video dude, good luck
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
