Yip Yip Yip...
03.28.2008, 02:17 AM
Originally Posted by lincpimp
True, but I removed the front endbell and drilled/tapped m3 holes in a 25mm spacing. You could have the shaft turned down, or drill out a pinion. I make my own mounts for these motors, so that is not a big deal for me. They are well worth the hassle, considering the price.
I wonder if I could find someone around here who could turn down the shaft and drill the holes for me. Will the kb45 fit the revo mounts with the holes re drilled?
03.28.2008, 07:12 AM
To turn down the shaft run the motor whilst in a vice and use a dremel or something similar with a cutting disc to cut down the shaft.
The KB should fit the revo mounts but the holes may have to be off centre if you wish to use the rear support(neu-they have a similar diameter).
Alternatively you could just make a plate with the 30mm bolt spacing and use that instead of the one included.
Yip Yip Yip...
03.28.2008, 07:54 AM
I don't think i would ever be able to grind down the shaft well enough using that trick. I'd make a mess for sure.
03.28.2008, 08:04 AM
Honestly, it isn't that hard. You just have to go slowly up and down with the disc at an angle to the shaft and make sure that you have a pinion available to check the shafts size. Just don't do too much at a time and if its close to sliding on use a bit of sand paper or something similar to get the last little bit off.
03.28.2008, 08:34 AM
i did the same with a stone on my dremel.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
03.28.2008, 03:13 PM
Video coming of my baja running with two actual baja's.
One is a 30.5 and the other has a 28.5 motor. They did start to pull past me on the top end.  Defiantly getting a kb motor  I am very happy with the chassis though, it handled great. They even commented how mine has better handling then theirs.
Something, anything, nothing
03.28.2008, 06:07 PM
It looks nice, but definitely looks to need more power. Can't wait to see more vids!
Yip Yip Yip...
03.28.2008, 08:16 PM
Yeah yours should have far better handling just because it weighs so much less.
03.28.2008, 09:40 PM
if you pm mike i'm sure he could make you a custom version of the neu motor plate to go from 30mm to 25mm..
03.29.2008, 06:23 PM
kyle u can put a lmt 3040 in your baja and it still wont catch mine. come on kyle where the vid of yesterdays run. but anyway its a nice build when i was getting my baja out of the car the yesterday to run with him i did not realize it was not a hpi baja until it made no noise.
TEAM FUSION
03.29.2008, 08:22 PM
That does sound like a challenge that an E-Baja can't hang with your weedwacker-Baja.
I don't think I would take that bet if I were you  cause we all know that it can be done, it's just a matter of $$$$ and electrics always win
lol
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.29.2008, 08:57 PM
We'll see...  I just ordered a kb-45 10L.  I might run 6s3p a123 with it.  His gas baja is fast, but I like a challenge  Video will be up Monday night.
03.29.2008, 09:03 PM
i know the power of brushless setups. b4 i moved into largescale cars thats what i had. the mega 22/45/2 he is going to try came from me. its a power house it pushed a 12lb 43" catamaran running on 22 cells to 39mph and was pulling less than 30 amps. my other baja not the black one in the vid he is going to post has a fully ported billet reed case motor that is 27.2cc around 7hp est. so im not too worried right now. plus if one loses ill just try another.
03.29.2008, 09:06 PM
are u going to turn the shaft down to 5mm or drill the pinions out also if u are running the strobe slipper is found some pads while moving to day u can have.
04.01.2008, 09:32 PM
Ok finally got the vids up. They are short and not very good.  I will get better, longer footage when I get my kb45-10L. I am wondering now if I should have just went with a kb8xl instead. Oh well hopefully I'm satified with the 10L. This was my first full run and it did great. I got a solid 20 minutes of run time  and no breakage at all. http://s283.photobucket.com/albums/k...t=DSCN6299.flv
http://s283.photobucket.com/albums/k...t=DSCN6295.flv
Linear Mode
