Does MM not work in 5S???
raptor50
Does MM not work in 5S??? - 03.30.2008, 08:07 PM
I have set up with bec and everything.. I had the same set up b/4 w/ older MM and it worked fine. does the New MM not work for 5S? I have Neu, 1515 motor and 5S 4800 to work with.. CC bec.. let me know..thanks..
Bomb-Proof
03.30.2008, 08:13 PM
Mine worked a couple times and then caught fire. Not the best 5s esc. Quark125b is much better for that, ultra smooth.
raptor50
Post 03.30.2008, 08:42 PM
where do i get that?
Bomb-Proof
03.30.2008, 09:35 PM
I got mine from Jamie at StarluckRC.com but he is out of town for another week I believe. I am not sure if he has any is stock or not either.
raptor50
03.30.2008, 10:32 PM
what diff. does that make where i get the MM? is ther an alternative esc thats not too expensive? thanks..
Bomb-Proof
03.31.2008, 10:02 AM
I dont know that it makes a difference..the newer ones are more picky it seems like. They are all a timebomb on 5s and will smoke, and could possibly take down the lipos with it. The people running it typically run on the street on wide open passes...half throttle is what kills it, the switching w/high voltage...and a 4 pole motor makes it even worse.
03.31.2008, 10:55 AM
Let's not forget that the MM is technically a 3s ESC...
loa
03.31.2008, 12:58 PM
Hello,
Wow! StarluckRC.com has NO product listed in every category (at time of posting)... Good way to make a business!
Loa
rschoi_75
Certified Spaceball
rschoi_75's Avatar
03.31.2008, 01:46 PM
chill out dude.... looks like he's re-doing his website. give him some time or order from another place. simple as that.
rcm xt8
rcm xb8
rcm crt.5
bdebde
That's All Folks!
bdebde's Avatar
03.31.2008, 03:10 PM
Originally Posted by loa View Post
Hello,
Loa
someone said he is out of town, hard to sell stuff if you are not there!
raptor50
03.31.2008, 03:47 PM
Enough about starluck. If he wants business he'll fix/stay at work. No biggie. also, He sells MM that will work with 5S? does he have some special treatment? anyways..
Will this work? built in bec 80amp. I have teckno revo w/ 1515 2.5 Neu motor. thanks..
http://www.readyheli.com/Kontronik_J...C_p/jazz80.htm
jhautz
jhautz's Avatar
04.01.2008, 01:40 AM
I dont see them being timebombs...Ive been running 2 MMs on 5s for quite a while and never had an issue. Both are going on close to a year now. As long as you set it up properly and gear it properly and a 25mm fan and they are just fine. One is a track setup and the other is a basher. Both run just fine on 5s. They were both in buggies and I just recently moved one of them over to a truggy on 5s and still not seeing any issues. I really think that most of the MM problems stem from people running Neu motors with them. The new software make them run OK. but they still dont run the Neus as smooth as they run a 2 pole motor. I get random cogging still and the cogging is what kills the esc. The 5s just makes it easier to fry when it cogs cuz everything is closer to the limit already.
The newer ones are a little more finicky like you said. But from what I understand, they either run on 5s, or they dont. It seems kinda luck of the draw. I dont have a newer one to reference though.
to make it...
or break it...
Silent...But Deadly
raptor50
04.01.2008, 01:48 PM
thats the set up I have!!! Neu and MM combo. If its gonna be this much heache and potential to cause fire, then Im gonna use the Jazz 80 esc..
I fly helis and this esc works really well.. German tech. will outshine all.. thanks for your help..
legobrains
04.01.2008, 02:41 PM
Is that why you are using a USA made NEU motor?
Serum
Serum's Avatar
04.01.2008, 02:51 PM
You guys ever considered buying a Quark controller from RC-monster? Rumour has it that he runs an rc-business too! (must be the worlds best kept secret.. )
