What is the diameter of a 46t mod 1 spur?
What is the diameter of a 46t mod 1 spur? - 04.01.2008, 07:57 PM
Title says it all.
04.01.2008, 08:29 PM
48mm.
04.01.2008, 08:30 PM
http://www3.towerhobbies.com/cgi-bin...?&I=LXSKZ4&P=7
This is the 46T Spur Gear for the Associated RC8 (ASCC0600).
FEATURES: Metal construction, silver in color
Replaces worn or damaged spur gears
INCLUDES: One 46T spur gear
SPECS: Diameter: 1.85" (47mm)_
Thickness: .39" (10mm)
04.01.2008, 08:37 PM
Something HAS to be up with that. For mod1, the diameter is 2mm + tooth count. So, 46+2=48. I wonder if the teeth aren't as tall/pointy or something?
04.01.2008, 08:49 PM
They vary across tower from 47 to 48.2mm...
04.01.2008, 10:04 PM
And will they fit in between E-maxx chassis braces with the FLM chassis? I think you know what I'm getting at.
04.01.2008, 10:11 PM
the diameter is twice the radius no they don't fit, they just barely hit, trimming 1mm off each side would do it, check this out-
ID:	4353   Click image for larger version
ID:	4354   Click image for larger version
04.01.2008, 10:14 PM
an rc-monster center diff/motor mount for the flm e-maxx chassis. I'm the second in the world with this design. Has a 8 spider 46 tooth diff, just barely hits, minimal trimming needed, sorry about the 2 megapixel pics
