Revracer
Revracer's Avatar
04.02.2008, 11:40 PM
ive never thought of husing honey as a compound... would it work well for tc racing and pan as well?
snellemin
2 KiloWatt RACER
snellemin's Avatar
04.02.2008, 11:58 PM
Bee spit is amazing stuff that works for me. But I wouldn't know if it would work for TC an pan cars as it's a thin substance. Try it out and see if it works for you.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Revracer
Revracer's Avatar
04.03.2008, 04:43 PM
well running foams... i could always try soaking the tires and then letting them dry in the sun or do whatever your doing only to a much thicker level to make it last longer... how many launches do you get out of one treatment?
snellemin
2 KiloWatt RACER
snellemin's Avatar
04.03.2008, 04:51 PM
I get one launch per "bee spit" treatment. After the run I clean the tires with water and reapply for the next run.
Revracer
Revracer's Avatar
04.03.2008, 06:55 PM
hmm...this is also on a rwd car that is putting down a lot more power... how do apply it and how thick usually?
snellemin
2 KiloWatt RACER
snellemin's Avatar
04.03.2008, 10:41 PM
I put two thin strips of bee spit down on a piece of lexan. Then I just roll the car rear tires on the strips several times untill it's coated evenly. Most of the time it's just a thin coat. Just do what works for you.
My Rustler uses a thicker coat then the 45oz camaro.
Revracer
Revracer's Avatar
04.03.2008, 10:56 PM
hmm... i might have to try that out... just do that about 10 times... i probably dont launch as hard as you off the line or ever really, but i do turn a lot harder then you... haha
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.29.2008, 02:16 AM
I went back to 48P gearing, and will run 4S. Refoamed and trued the TM nitro wheels. Gonna need all the traction I can get. Wheeliebar should work better now, with all the ballbearings as wheels and enough flex to keep the rear tires planted at launch. Motor choice is a Lehner Basic 5300. Previous motor was a 9T hacker C40.
Should be a fun car throughout the year.
In this vid you see the old setup in action. It's in the middle of the vid and it was taken by Sunnyhoutx. That was with the 9T hacker and 3s A123.
http://www.youtube.com/watch?v=tDo0Jt4X3kw
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.29.2008, 02:46 AM
That nitro takes off quicker than I thought it would. lol, the tyre didn't last long
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
