jhautz
jhautz's Avatar
04.10.2008, 04:41 PM
I had that problem once when I went a little crazy with the blue locktight on the grub screw. I seeped down n between the pinion and shaft and that sucker was stuck on there. A cigartte lighter on the pinion and then carfull prying got it off though. just go slow and try not to overload the motor bearings while you are prying at it. A gear puller is the safe way to do it, but its kinda hard if you cant get the motor off o f the mount with the pinion on it.
to make it...
or break it...
Silent...But Deadly
neweuser
neweuser's Avatar
04.10.2008, 04:45 PM
And you may not even be able to find a gear puller that small. :)
mkrusedc
NeuMaxx
mkrusedc's Avatar
04.10.2008, 05:19 PM
I haven't put a flat spot on my Neu yet. The pinion came off twice before I used loctite. So far no problems, but I am a basher. If mine comes off I won't lose a race.
I have used a soldering iron to heat the grub screw and then used a pinion puller to get stuck pinions off.
04.10.2008, 05:42 PM
Would this pinion puller work? http://www3.towerhobbies.com/cgi-bin...&I=LXHHN3&P=ML
mkrusedc
NeuMaxx
mkrusedc's Avatar
04.10.2008, 06:34 PM
I have not used that one but it says for motor shafts 2.0mm-3.2mm in diameter. Neus are 5mm shafts.
Here is one that should work 1mm-5mm shafts.
http://www.lynxmotion.com/Product.as...&CategoryID=72
Shark413
Shark413's Avatar
04.10.2008, 06:48 PM
I have the Tower gear puller and it works fine. The only issue is the space between the sides of puller can only fit up to a 13T pinion (tried a 13T and it fit, with a tiny bit of space, so a 14T may work as well but it would be close). Anything bigger won't fit.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
