Looking for someone with a Hyperion Charger
loa
Looking for someone with a Hyperion Charger - 04.16.2008, 11:09 AM
Hello,
Just got a Hyperion Charger (the small 0606i AC/DC). I've read the manual all the way through and it's pretty simple and straightforward.
1 thing I can't find: can I set the min/max voltage for discharging or charging a LiPo??
I let it charge my 2 LiPo batteries (2s 8000) one at a time, until they got to 8.4v, which is supposed to be the maximum. But the charger didn't stop.
Does anyone know its cut-off point? Can I set/change it??
Thanks
Loa
TexasSP
Something, anything, nothing
TexasSP's Avatar
04.16.2008, 11:20 AM
It can go over, mine always does. As far as the discharging, I only have used it on mine a few times and can't remember how.
www.cubicle101.com
loa
04.16.2008, 11:28 AM
Thanks.
But where does it stop?
And how high do you let it go?
Loa
04.16.2008, 11:29 AM
It will stop a 4.2 / cell - it just changes mode at that point and goes constant voltage - It also could be just finishing off balancing...
No worries the hyperion chargers are great... I have 3 - 606ac/dc and 2 of the new 5idp
loa
04.16.2008, 11:38 AM
Ok, I'm charging a pack right now, I'll see when/if it stops at 8.4 volts.
Loa
04.16.2008, 11:48 AM
It won't stop straight away but leave it and it will be fine. These chargers give a constant current charge rate at 75% the cell capacity until the pack voltage reaches 3.6 volts per cell. This charges the pack to about 80% of total capacity. At this point the charger switches to a constant voltage charge rate of 3.6 volts per cell to top off the battery. To charge a fully depleted pack typically takes about one and a half hours.
Press the left hand button once charging and you can scroll through the settings including input/output voltage and individual cell voltages. ATB.
loa
04.16.2008, 12:24 PM
Thanks.
It's indeed holding steady at 4.22V and 4.21V.
It's not hot right now, but should I expect a little heat before it ends, like with NiMH cells?
Thanks
Loa
azjc
04.16.2008, 12:27 PM
Originally Posted by loa View Post
Thanks.
Thanks
Loa
it shouldnt, mine never even get warm
04.16.2008, 12:31 PM
Nothing noticable - I always charge in a lipo sack though
loa
04.16.2008, 03:19 PM
Thanks
It didn't get warm at all.
I don't have a lipo sack, but I'm in the basement on the concrete, away from anything that could burn.
Loa
YogyBrushless
04.17.2008, 02:39 AM
u dont want heat when charging a lipo, it will be fine with a hyperion dont worry about it :)
auto2
04.17.2008, 07:13 PM
another point is if yur pack is way out of balance ( llike from another changer or not balancing) the charge will take forever cause it is trying to balance the pack.
