CC Bec need a switch?
CC Bec need a switch? - 04.23.2008, 11:45 AM
Do I need a switch between the bec and the reciever, or can I just plug it in and everything is powered when I plug in the battery?
skellyo
skellyo's Avatar
04.23.2008, 11:48 AM
No switch necessary. Your Rx will get power as soon as you plug your battery into the ESC (assuming your BEC input is wired in parallel with the ESC input).
04.23.2008, 11:51 AM
thank you
TDC57
TDC57's Avatar
04.23.2008, 04:14 PM
I just used the 10amp CC BEC on my GEVO project. I simply connected the Red (positive) and black (negative) from the BEC to the red & black off the ESC / battery wire and ran my BEC wire to my Rx.
Please see photo’s below..
Thanks – helps that helps..
Shaun.
Nothing!.. Hahahahaaa..
04.23.2008, 04:20 PM
sweet truck shaun, my build is a month or 2 from completion,pics will be posted
TDC57
TDC57's Avatar
04.23.2008, 04:23 PM
Thanks paralyzed!.. Once I finally received all of the parts it took me a total of 52 hrs of Fab time.
I'm looking forward to see your BAD BOY!..
Have a great one and keep us updated as progress is being made..
Shaun.
