Neu motor / LST2
KaztheMinotaur
KaztheMinotaur's Avatar
Neu motor / LST2 - 04.16.2008, 08:12 PM
I am thinking about a Neu 1515 1Y as a replacement for a Feigao 8XL. It will be in a LST2 that weighs just under 13 pounds, running a Hydra 120 on 5S.
Thoughts?
Has anyone used the FD motor mounts with a Neu?
TexasSP
Something, anything, nothing
TexasSP's Avatar
04.16.2008, 08:45 PM
It should rip. There are several on here using that motor with 4 and 5s and on the 5s they all say it's a beast. Now the ones I know of are on E-maxx's and Revo's but the weight is near the same.
www.cubicle101.com
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.16.2008, 10:55 PM
how are you gonna get that LST less than 13 Lbs...? stock LST without engine is 12.0 Lbs....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Patrick
Patrick's Avatar
04.17.2008, 05:30 AM
Are the FD mounts those rings that clamp around the motor? If they are then they probably won't fit a neu.
Feigao and most other smooth can 540/550 size motors are 36mm diameter.
Smooth can neu is 39.6mm
Finned neu is 43.8mm
For 5s you could use the 1515 1y (2200kv), 1515 2d (2050kv) or 1515 2.5d (1650kv), just depends on how much power you want, and if you can get a motor mount to work with a neu.
KaztheMinotaur
04.17.2008, 06:13 AM
That weight might have been before battery.
Yes they are the clamp mounts.
Any heat issues with running the 1Y on 5S?
badassrevo
04.17.2008, 08:24 AM
excelent motor. I use one in my 8ight T 20+ min run time on the Poly Quest 4s 6000
KaztheMinotaur
04.17.2008, 08:49 AM
So I weighted it before I went to work this morning: 13.05 pounds with battery.
lucias
lucias's Avatar
04.17.2008, 09:23 AM
Fine Design offers NEU motor clamps on there website...
I just looked they are $32..
KaztheMinotaur
05.07.2008, 12:19 PM
Any ideas on what temps I should see with the 1Y on 5S?
