05.08.2008, 09:47 AM
I would say so. If the "high power" brushed motor hookup method is the same as the MM (where you use all three motor wires as the negative wire, and use the battery positive for the positive wire), it would be good for around 600A!
Since a radio receiver simply sends 1ms-2ms pulses every ~20ms to the servos/ESC, all you have to do is emulate that. I've built a small circuit to test servos using a 555 timer, a couple of small caps, and a few resistors. The caps and resistors set the pulsewidth duty cycle and frequency. Quick and dirty for less than $10. Then, it would be a matter of using a potentiometer in place of a resistor to allow a variable output. The only thing I would be concerned about is throttle "drift" if the pot gets worn/dirty over time. I still have the schematic somewhere if you want it (just have to find it).
05.08.2008, 10:13 AM
Or just buy something like this
http://www3.towerhobbies.com/cgi-bin...&I=LXVK79&P=FR
Maciolus
05.08.2008, 10:26 AM
I want more of these fans!
5V x 0.19A = 0.95W
5.5V (MMM BEC) x 0.19A = 1.045W
Normal PC 25mm fans have no more than 0.5W
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
05.08.2008, 11:25 AM
Originally Posted by tc3_racer_001 View Post
W_N, what is TEC/WB stand for?
I'm gonna go with ThermoElectric Cooler/Water Block.
Not sure why you'd want to? Air cooling is much more efficient in this application.
TEC = power hog. TEC's are great if cooling something below ambient improves performance.
Water block needs water, pump, radiator, which will use more power and add a hell of a lot of weight.
05.08.2008, 11:28 AM
@Arct1k: Yeah, but building it is more fun. Seriously, I wonder how hard it would be to use a rotary encoder instead. In an R/C, a little throttle signal "drift" is acceptable to a degree, but not for personal transport (safety). An encoder style adjustment would be more resistant to wear and value drift.
@Maciolus: You are making the assumption that the CC fan has a higher airflow output because of the higher power. It probably does, but there is a point where faster airflow doesn't help as much as you would think. Just getting any active airflow is a HUGE help, but increasing it by just a few cfm's will provide marginal benefit.
I'm gonna wait until Castle releases the ESC/motor combos, and then remove the fan, add a larger heatsink, and remove the top part of the case to allow better passive airflow through the fins.
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
05.08.2008, 12:18 PM
Do you have a circuit diagram for this? I seams like a fun thing to do if I was bored sometime
Thanks
My Rides:
Tamiya Dark Impact - Team Losi Micro B - Cen Mini Madness - Soon to be BL Xray XB8 TQ
05.08.2008, 12:30 PM
http://www.free-circuit-diagrams.com...e-servo-tester
johnrobholmes
johnrobholmes's Avatar
05.08.2008, 12:40 PM
servo tester plus http://www.electricvehiclesusa.com/p.../th-magura.htm equals perfect
---JRH---
05.08.2008, 02:06 PM
The only trouble with that one is it uses a PIC, which you need to program and upload. A little difficult if you don't have the tools to do this.
05.08.2008, 02:13 PM
Or http://www.tuug.fi/~isaarine/electronics/servo-test/
05.08.2008, 02:29 PM
That's better. It's been a while since I've seen individual logic gates...
These are a few 555/556 timer based circuits I was thinking of:
http://hades.mech.northwestern.edu/w..._Servo_Circuit Although, I'd probably use a 556 timer (dual 555's) for space and convenience...
http://members.tripod.com/Sarconastic/servodriver.html
http://www.seattlerobotics.org/encod...Excerciser.htm
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.08.2008, 05:53 PM
W_N, what is TEC/WB stand for? its sick, looks much better than in those other photos ive seen, cant wait!!
Correct. It would be more for show than go, I just think TEC's are really cool! You'd only need to run about 50-70W through it to keep it nice and chilly. That kind of power is nothing compared to the power that would go through the ESC at ultra-low temperatures. I only suggested the idea because of the single FET board, which makes it possible.
Pdelcast
Pdelcast's Avatar
05.08.2008, 05:55 PM
WE DO NOT recommend attempting to remove the MMM heat sink. It would be difficult to do so without damaging the FETs. (besides, removing the heat sink will void your warranty. )
Patrick
What's_nitro?
05.08.2008, 05:57 PM
I see. So it IS thermal epoxy! That would be difficult, and yes it would most likely pull a few FETs off the board!
05.08.2008, 06:18 PM
If it's the same stuff you use on the MM, a few minutes in the freezer makes it quite brittle and easily pops off.
