aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.08.2008, 08:57 PM
I've ran 8XL on 6S as well on an LST... but it probably doesn't get those the rpm limit when under load....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
lutach
lutach's Avatar
05.08.2008, 09:02 PM
Originally Posted by JOHNNYMAXXIMA View Post
I have a spare motor and a spare speed controller. The only problem is that the motor is a 18th scale Dynomite C4 9200kv and the controller is a BK 9920.
Over kill on the contoller I know but would it work?
Check this out: http://www.youtube.com/watch?v=6uPXuaiVuk0
05.09.2008, 12:06 AM
I run a 15l feigao on 5s lipo and have not had any issues, that is around 30k.
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
05.09.2008, 02:53 AM
Yeah that's it. I was gonna say you need to keep the voltage under like 5 volts or it will over-rev the 9920. I believe the limit is 42k. That's a 1S motor!
Well I just tried it on a 1s that I had. Same pulsation. I will try to reprogram it and see if that does anything.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.09.2008, 06:52 PM
Could it be interference??? I have no idea from what...
Yeah, I would try reprogramming and see if it helps. Does it "glitch" with any of your other motors?
JOHNNYMAXXIMA
05.11.2008, 02:58 PM
Well I reprogrammed it and no dice. I hooked up an old 9L that I have and it worked fine. I guess the little motor doesn't like the big speed control.
