JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
05.11.2008, 05:04 PM
Originally Posted by FatBoyRacing View Post
I can't even get through the install completely. At the very end is when it gets me.
That's what happens to me also. It leaves you with no Castle Link installed at all.
05.11.2008, 07:48 PM
Ditto It has just done the same on my wife's xp machine to I think it ias a castle issue
JerryF504
JerryF504's Avatar
05.11.2008, 09:49 PM
I think so too, I sent them an email a little while ago. I'll post up when they reply.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.11.2008, 10:10 PM
I'd try deleting any temp file left by the installer. Not sure where those temp files might be exactly but try the usual places.
blueb8llz
05.12.2008, 01:59 AM
so for all you guys that cant run the software, does this mean you cant run your cars either? or is there a default so you can still run your truck but just cant mess with the curves yet? if there is a default, will it work on lipos and does it have a default lvc? or is default only programmed for nicd/nimhs?
jhautz
jhautz's Avatar
05.12.2008, 07:59 AM
The stick programming should still work without a computer to get yourself up and going at least. Can at least set it to auto lipo mode.
to make it...
or break it...
Silent...But Deadly
05.12.2008, 10:11 AM
This isn't a cache issue - I've traced all files written etc - The rollback process is actually very clean at removing the install files.
I was hoping it was vista specific but it appears if there is something else in play. It was a touch of a suprise really to have issues with my wifes machines as we have quite different setups...
I hope the arn't having QA issues with the software install and the MMM...
JerryF504
JerryF504's Avatar
05.12.2008, 11:45 AM
I can reinstall the older version that I downloaded a few weeks ago, but it doesn't allow me to set the lvc on the Monster above 17.1 volts. I can still run it just without lvc.
rabosi
05.12.2008, 11:55 AM
I don't have an issue with the new version and I also run xp sp2. Maybe you guys having issues have a conflict with other software or drivers. Have you tried closing any apps that may be running in the background?
05.12.2008, 12:17 PM
Anything is possible given that PC setups are very variable on OS / Software - I'd like a version of software with just the msi and cab package to try first. Then a zip of the inner cab files for me to try creating my own cab.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
05.12.2008, 12:40 PM
Installs fine on my vista box, no problem.
blueb8llz
05.12.2008, 03:11 PM
so if the software does not work i can stick program it to lipo mode still? so that auto lipo mode will be able to read that its 2 packs 2s and lvc? if i wanted to run on nimh after the lipo packs, do i have to reprogram or can i just run it like that?
05.12.2008, 03:27 PM
Worked fine for me, wrote over the existing file without any issues. I have xp.
JerryF504
JerryF504's Avatar
05.12.2008, 05:51 PM
Yeah, I don't have anything running except the installer. I'm at a loss. I also tried on another computer and got the same message. They are both Dells maybe that has something to do with it. One is a E1505 (home edition) laptop and the other is a XPS 600 (media center edition)
rabosi
05.12.2008, 07:00 PM
Yeah it sure seems like whatever resources the CC install needs is not being freed up. You guys that are having this issue should post your system setups to see if there's a commonality.
