New CRT.5 coming-PBS- pivot ball steering
Finnster
KillaHurtz
Finnster's Avatar
New CRT.5 coming-PBS- pivot ball steering - 06.09.2008, 09:59 PM
http://www.hongnor.com.tw/eng/pviewi...ea=45&cat=159#
We have received many requests from our customersfor a Pivot Ball Steering System to satisfy their market.
The Pivot Ball front and rear end allows for more adjustments to satisfy all drivers driving styles.
We have developed a special high impact and more durable nylon with better wear properties for the steering knuckles.
This is only for the RTR, but they will have a conversion kit. Too bad no fix for the servo saver.
Duster_360
06.09.2008, 10:15 PM
I guess they'll offer a PB conversion kit like DTX does for the buggy model Vendetta as an upgrade to the ST type suspension?? Sooner or later....
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.10.2008, 02:29 AM
Nice little update for the CRT.5, OFNA are mean't to be bringing one out aswell - Hyper ST Mini
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Finnster
KillaHurtz
Finnster's Avatar
06.10.2008, 07:15 AM
Will PBS be all that much better than a kingpin design? I tend to think of pillow balls popping out, but.... saves a lot of cnc upgrades tho
MetalMan
MetalMan's Avatar
06.10.2008, 06:19 PM
I like traditional c-hub/kingpin/whatever better. In my experience it's been more durable and smoother since it's meant to fit together perfectly without any adjustments (PBS has those caps that need to be tightened 'just right'). This is an upgrade I certainly won't be using.
GO-RIDE.com
06.10.2008, 09:48 PM
It certainly looks like the PBS hub is stronger than the current c-hub and steering knuckle the .5 runs. I also like the look of the upper arm w/o the turnbuckle that is a constant bending problem with the current .5. I'll probably give it a try when the upgrade kit comes out.
E-8ight - Tekin RX8 2000kv/4S
Sammus
Sammus's Avatar
06.17.2008, 06:19 AM
URGH! Pivot balls SUCK! unless you have dust covers like the revo they just get worn away all all sloppy in no time at all.
crazyjr
crazyjr's Avatar
06.17.2008, 10:28 PM
It looks like it will have big bore shocks by the list, I like the improvements
GO-RIDE.com
06.18.2008, 12:27 PM
10mm is the same size shock that comes on the original CRT5. They called them "big bore" on that box too.
Serum
Serum's Avatar
06.18.2008, 12:37 PM
Odd to see they went for the pillowballs instead of the Chub/steering knuckle.
I wonder what them made do the change..
crazyjr
crazyjr's Avatar
06.18.2008, 01:27 PM
never looked at the specs on the origional, didn't know they were the same
GO-RIDE.com
06.18.2008, 01:41 PM
Yah, it's pretty lame for them to call 10mm big bore when that is actually a bit smaller than my Losi 10th scale shocks for a vehicle that is at least 20% lighter. At least you can get 13mm big bore stuff, from other cars, pretty cheap for the crt.5. It takes away a bit of the sharpness in handling, but it is so much better on rough tracks it is well worth it.
crazyjr
crazyjr's Avatar
06.18.2008, 04:58 PM
honestly, i never had a handling problem with my .5, it seemed to be nice no matter how rough the track
Finnster
KillaHurtz
Finnster's Avatar
06.18.2008, 05:14 PM
Really? Mine seemed to bottom all the time out and bounce around alot. The BBores helped out quite a bit settling things down
