any one out there have a 8-9xl they dont want
big greg
any one out there have a 8-9xl they dont want - 06.14.2008, 10:11 PM
the one in my buggy has seen 220 a few times and i added a fan and thermal coumpound, geared 13/48 in an 8ight and after 20 mins i still thermal the motor. upsets me to, i thought i would be ok with the fan on it, nope not really!
azjc
06.15.2008, 12:53 AM
what batteries and are ESC are you using? and your ESC settings
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
06.15.2008, 03:57 AM
you can try one of these bad boys...similar specs to the fiegao/wanderer 9xl
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
kd36
Front mount holes are 25mm apart.
Dimensions: 36×74mm
Shaft size: 5mm
Weight: 370g
Spec.
Kv: 1900rpm/V
Idle Current: 2.6A
Resistance: .0091
Max Amp: 75A
Designation: 5408409XL
fiegao 9xl
RPM/V: 1853
Max Current Limitation: 74A
Resistance: 0.0097
IO(A): 2.5
Dimensions (diameter x length): ø35.8 x 74 mm / ø1.4 x 2.9 in.
Weight: 378 grams / 13.33 oz
big greg
06.15.2008, 05:07 PM
batt im using a zippy-r 4500 21c-31c, mm esc. punchcontrol 10% motor timing normal, brake 50% motor start medieum
