Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
06.18.2008, 05:40 PM
I was going to call you guys "end users", but I thought that was going WAYY too far! I don't need drive-by's at my house!
bdebde
That's All Folks!
bdebde's Avatar
06.21.2008, 11:09 PM
What happened to the Lehner motor specs in the calculator Brian?
06.22.2008, 12:47 AM
I took them out because Mike no longer has them and the list was getting kinda long for something fewer people have. Actually, they are still there, just commented out. I suppose I could add them back in but put them at the bottom of the select list...
jayjay283
jayjay283's Avatar
06.22.2008, 01:01 AM
Great program love it and use it alot, the Emaxx 3905 and new erevo come with 32p 68t stock spur and you have everyone but that one as far as I can tell, any chance of popping that in there next time you get a cravin to update ?
06.23.2008, 03:36 PM
Done. Also re-added the LMT motors, but they are at the bottom of the list now...
06.23.2008, 03:42 PM
Brian re Buggy / Truggy / Truck comment it was in the brushless motor selector item.
You have a field for "Enter approximate vehicle weight (?): " I was thinkink that this could have drop downs based on typical weights for a Buggy / Truggy / Truck... I guess 8 / 10/ 12 lbs?
PS HP Pro in "Enter Front/Rear Differential Gear Ratio " is Hot Bodies LSP and could move into HPI...
Great series of updates! Buy yourself a pizza! ;)
06.25.2008, 10:46 AM
Gotcha! But, I don't think I'm going to add that just yet. The weights of the vehicles varies a lot and I think it would be easier to just enter a number in that field.
Someone submitted "HP Pro" to me a while back and had no idea what it was. I don't follow the vehicle names as closely as most of you guys do. Anyway, I renamed it and moved it to a newly created "Hot Bodies" heading. BTW: Don't enter "hotbodies.com" while at work. It's "hotbodiesonline.com". I really should have known better.
Thanks! Can I buy myself Subway instead? I like that better...
Also fixed a bug in the wiring page when using FireFox that someone over at the Traxxas forums found.
brushlessboy16
brushlessboy16's Avatar
06.25.2008, 10:54 AM
hahaha, just like trying to go to Dicks sporting goods..
06.27.2008, 11:02 AM
Silicone Oil Mixture Calculator
This calculator is based on the code from http://www.gesilicones.com/gesilwiza...ng/fluid2.html.
Viscosity of Fluid A 45
Viscosity of Fluid B 30
Target Mixture Viscosity 60
Mixing Percentages
Fluid A 171%
Fluid B -71%
I know non a valid scenario but you could have validation on input that Fluid A >= Target >= B or B >= Target >= A.
06.27.2008, 11:03 AM
Temperature Calculation - Any thought of adding Kelvin?
06.27.2008, 11:06 AM
Two Speed Gear Mesh Calculator - Might want to add a note that this is for Mod 1 gears
Thanks all
06.27.2008, 12:20 PM
Arct1k, are you trying to find work for me to do?
Fluid calc: Good idea. Didn't change it too much from the original aside from visuals. Might add that feature.
Temp Calc: I think C and F are good enough. Who (besides you apparently) uses Kelvin when measuring temps?
Two-speed mesh calc: Why does it matter what pitch it is? I know the code is technically using Mod1 to get the gear diameters, but the ratio is what matters. The only reason Mod1 is currently used is because I was going to add shaft-to-shaft distance, but decided not to, and didn't feel like changing the mesh code again.
brushlessboy16
06.29.2008, 10:59 AM
Medusa motors run 60k max rpm not 40k.
:D
07.01.2008, 10:07 AM
Fluid calc: NP
Temp Calc: Well Kelvin did... and it is rather cool ;) Not seen too many people measure distance in rods either
Two-speed: Hmm yes - its all relative...
07.01.2008, 12:52 PM
:SIGH: I suppose I can add Kelvin.
Added the extra oil mixture validation.
Added the CRT diff ratio.
The fix for the erroneous 40k rpm warning for the Medusa motor was a little different. The 60k rpm limit was entered correctly for that motor, but my warning system was using the old drop-down list method, so it was actually giving you the rpm limit of a whole different motor. Fixed now.
