mm still cogs like crazy w/my new NEU motor -
07.03.2008, 05:31 PM
I have the latest firmware and it still coggs...any ideas? Esc was fine w/the 9xl
That's All Folks!
07.03.2008, 05:40 PM
what does it say for firmware number on the last page of castlelink?
07.03.2008, 05:41 PM
1.17
RC carbon junkie
07.03.2008, 05:50 PM
Double check your motor connections.Ive had cogging when I first installed connectors on my 1512/1.5D the wires coming out of the motor were huge and 1 of my connectors wasnt soldered correctly.I resoldered the loose connector and all ran smooth.
07.03.2008, 05:57 PM
All connections are good. The buggy goes great for the first 10 sec.,but, as i turn around and accelerate, it coggs like crazy. Let off the throttle for 2 sec and then it seems ok until I turn and accelerate hard again.
07.03.2008, 07:26 PM
your batteries? or the esc? i have a feeling that they justa cant supply the current required, and once u have used the burst rating (10 secs) then it struggles for the power.... try another pack from somene else if you can and see if that helps :)
hope you get it sorted.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
07.03.2008, 08:41 PM
Well, I just put my 9xl back in and ran it for 15 min. and the esc ran perfectly...go figure...I guess the esc has an attitude problem w/the Neu!
Yip Yip Yip...
07.03.2008, 09:10 PM
What neu motor is it?
07.03.2008, 09:18 PM
1512 1.5yf ... Maybe it does need more juice...5s
Something, anything, nothing
07.03.2008, 09:20 PM
What you are describing sounds like a current issue, not a cogging issue. True cogging only occurs right at start up when the esc has trouble finding the rotor position. What batteries are you using?
07.03.2008, 10:12 PM
I am using Elite 4s 25c rating
07.03.2008, 10:14 PM
Even w/my 9xl there is a SLIGHT hesitation at start up.
07.04.2008, 12:43 AM
You have your timing set to the lowest position? Neu motors, at least the 1515's are suppose to be set to a low timing setting.
07.04.2008, 08:10 AM
It is set to a low setting, I don't recall the value off the top off my head, but I will check later today. MY timing is set for 5 so maybe I will try to bump it up to between 8 and 10 and see what happens.
08.18.2008, 05:56 PM
What ever happened with this? I need closure DAMMNIT!
Linear Mode
