Diff swap combatability -
07.13.2008, 09:20 PM
Will a center diff from a hyper 8.5 fit into a crt?
07.14.2008, 11:54 AM
Unless Im mistaken, all 1/8scale diffs & center diffs are the same size all bar a one or two, and they all use the same sized bearings, so it should work okay.
07.14.2008, 11:59 AM
At a min i think you would have to buy a hyper front support, top plate and motor mount...
07.15.2008, 04:11 AM
if you want some more info let me know, but i know that all the hyper diffs are the same (dimensions) so if you can find any info regarding the hyper 7 then that should be applicable for this :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
07.15.2008, 03:25 PM
The Hyper 8.5 diff should be more or less a direct fit to a CRT. Two reasons: it's a standard size (Kyosho diff), and two, they are both Ofna.
07.15.2008, 03:27 PM
Not so IIRC - Hyper is Hoboa and CRT is Nor Hong - In the USA they are both distributed by OFNA but different companies...
Easiest way to tell is Mike makes different motor mounts for Hyper and OFNA.
07.15.2008, 03:39 PM
But they are still both standard Kyosho type center diffs.
And I'd bet the only difference in Mike's motor mounts between the Hyper/CRT is mounting hole separation - the OP didn't specifically state that he (she) is interested in swapping the entire center diff unit including center bulks.
Linear Mode
