07.27.2008, 12:47 AM
If you are running an external BEC try disconnecting that and running a receiver pack to eliminate the external BEC as the problem. The other thing that could be possible I suppose is the steering servo going bad and creating some sort of interference int he signal of the whole system, but I think the BEC is the more likely culprit.
I had a similar issue with a bad steering servo. As I pulled the throttle the servo would twitch a lot and stay off center. It did not casue any issues with the control of the esc though.
Try a rec pack, and make sure it is fully charged, a pack with low voltage will cause all kinds of problems...
hailmick
07.27.2008, 02:41 AM
try switching your steer servo out like the boys above have said
my buggy has a twitching steering servo but its a nitro its even worse when steering
Trick440
07.27.2008, 01:21 PM
I think we maybe on track. I tried the stock reciever and same problem. I unhooked the steering servo and problem went away. But there is no steering servo hooked up. Im going to hook the stock steering servo up and see what happens.
brushlessboy16
brushlessboy16's Avatar
07.27.2008, 01:31 PM
are you running UBEC?
Trick440
07.27.2008, 01:54 PM
Not running a BEC.
It looks like the problem was a brand new Hitec. I only rode on this new servo a few times. I put the a stock revo servo in and its all good. Alot weaker steering but she runs....
I'm off to BaSh!!!
brushlessboy16
07.27.2008, 02:08 PM
wooohoo, i dunno if i helped but..Glad to be of assistance
