mamba max won't calibrate!
kyosho501x
kyosho501x's Avatar
mamba max won't calibrate! - 07.26.2008, 09:43 PM
my mamba max won't let me calibrate it, i just goes straight to the three LEDs. only the servo works
hyper 8- workin on conversion
Sammus
Sammus's Avatar
07.26.2008, 11:56 PM
Same happened with mine, but it was OK with a bec. Mines on its way to castle now.
07.27.2008, 12:49 AM
What radio are you using?
If it has a bunch of adjustments, make sure that everthing is centered, or set at full.
Epa, trims and any other throttle adjustments must be centered or maxed out before programming the esc. Also make sure that you have the lvc set properly and are using a fully charged battery.
Sammus
Sammus's Avatar
07.27.2008, 12:50 AM
Yeah sorry I should have mentioned that. My esc was faulty though and wasn't receiving any inputs whatsoever, wasn't even beeping at all or anything on start up.
kyosho501x
kyosho501x's Avatar
07.27.2008, 10:38 AM
im gonna send this to castle again, i already sent it to them once but they still didn't fix it
Sammus
Sammus's Avatar
07.27.2008, 10:47 AM
They test them all. Maybe its a problem at your end. Maybe some silly suggestions but:
1) Do you have the motor plugged in? You wont hear any of the tones unless the motor is plugged in.
2) Are you using a Spektrum radio by any chance? Spektrum take a bit longer for the Tx/Rx to bind to each other after power up, so sometimes the esc wont read the throttle input before it arms. You can change the startup delay with castle link. Some other radios I think exhibit this behaviour, not sure which ones though.
Robert
07.27.2008, 10:57 AM
They must test them before they leave. It's got to be something on your end. Give their tech support a call.
revo guy
07.27.2008, 11:44 AM
reverse your throttle channel on radio and reverse 2 motor wires it worked for me with my mamba 25 might work for u 2
kyosho501x
kyosho501x's Avatar
07.27.2008, 12:04 PM
i tried everything but nada, i got the stock system to work, but now its always shutting off when i crash. i think it might be that my battery must be dead. plus i forgot how to assemble a side by side pack. plus is it okay to let the battery submerge in water or get wet?
brushlessboy16
brushlessboy16's Avatar
07.27.2008, 12:09 PM
i don think any batteries and water mix lol
kyosho501x
kyosho501x's Avatar
07.27.2008, 12:16 PM
i know that but how do i water proof it? and how do i assemble a 6 cell pack the correct way? any vids
brushlessboy16
07.27.2008, 12:29 PM
i wouldnt know, i run lipos
tc3_racer_001
tc3_racer_001's Avatar
07.27.2008, 05:50 PM
just line them up in opposite directions and then solder the +ve to -ve an dso forth and on each end wire the wire or connector onto the battery. u will want more than a 40W iron... (i managed but i would recommend an 80 or so watt.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
kyosho501x
kyosho501x's Avatar
07.27.2008, 08:23 PM
well im gonna build a wooden battery jig to help me cause i don't have one that's why the job was so hard
