My 12020 Has Gone Crazy (help!!!)
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
My 12020 Has Gone Crazy (help!!!) - 08.04.2008, 11:10 PM
As the title has suggests, I am having some issues with a BK Warrior 12020...
I recently put together my first brushless system with with a Fiegao 8xl and the BK 12020 combo.
The truck (an emaxx) ran really well and I was having quite a bit of fun with it...
Trying to find even better results with power output, I played with Two different pinions, a 18 tooth and a 20 tooth.
One night I did some tests on asphalt just to see what kind of torque I was getting.. I squeezed a little hard on the throttle and the truck went from wheels to roof in a split sec.. But there was no roof really, as I was doing the test without the body mounted.. The truck landed on the heatsink attached to the motor and crushed some of the fins .. The motor did not spin the first time I squeezed throttle... then I notice the Motor plate was bent. when I removed the motor and "straightened" the plate, the truck work again... A few days later... it stopped again. I tried to re-programme the BK... When I ran it, It got very hot and refused to spool up... It just cogged like crazy..
My first thought was the motor was damaged.. I noticed that the bearings had quite a bit of play in them, so I ordered a new pair... but when I tested again... It did the same... So i ordered a new motor and installed it tonight, but to my disappointment, it did not work... So now my attention has been drawn the BK controller...
Has anyone had this experience before? And does anyone have any suggestions? The biggest problem I have now is that I live in Jamaica.. They are no hobby stores here, so i have to ship everything I need to the island (this is a real pain)..
Any help will be appreciated.....
Alien
jhautz
jhautz's Avatar
08.05.2008, 01:06 AM
are you sure the motor mount is bent back perfectly straight. If the gears have any misalignment they will have drag in the mesh which can cause all kinds of problems.
to make it...
or break it...
Silent...But Deadly
ANGRY-ALIEN
08.05.2008, 01:23 AM
Oh yeah... I forgot to mention this little detail, the motor mount was replaced with a new one.. The gears are meshing well... even when the motor is off the mount, it will behave same...
It's like, whenever I am trying to rev it... it does not want to... Hmm... another thing I forgot... the control and the motor got really hot the first time encountered the problem, so much so the,
the heatshrink started to melt off the BK. When I squeeze it gently, it will run smooth(ish)..
Alien
bensf
08.05.2008, 02:46 AM
Do you know what your timing is set at? I've heard that this can happen if the timing is too high. I'm not entirely sure about it, but it wouldn't hurt to check.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.05.2008, 03:17 AM
Alien
It sounds like you may have cooked it. It's possible though that something has just come unsoldered though. It may be possible to repair it.
83gt
08.05.2008, 07:11 AM
I had a bk that behaved the same, and I found a resistor on the back that was hanging half off the PCB. I replaced that resistor and it ran good until I shorted the motor wires and smoked it. Not sure if that could be an issue with you. I'd go ahead and remove the shrink wrap and give it a good looking over.
J>
ANGRY-ALIEN
08.05.2008, 11:50 AM
I am not so sure I know how to do that... Can you explain how?
I have not found any burnt element or loose items yet... I however saw a little dent in the back of one capacitor, not sure if this will be causing the trouble.. I think this happened during the crash too, not sure though... You can see the images below..
J>
The boards look fine... every tight...
Alien
ID:	5180   Click image for larger version
ID:	5181   Click image for larger version
ANGRY-ALIEN
08.05.2008, 11:57 AM
Some more clips of the BK... There is another pic below that highlights the suspected Cap..
Alien
ID:	5185   Click image for larger version
ID:	5186   Click image for larger version
ANGRY-ALIEN
08.06.2008, 09:11 PM
Anyone?
joeling
joeling's Avatar
08.07.2008, 08:02 AM
can't make out the details but the jumper pins to enable/disable BEC looks a little desoldered
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
ANGRY-ALIEN
08.07.2008, 10:03 AM
Regards,
Joe Ling
Hi Joe Ling, All both jumpers are still solid... I can't see any crack or broken solder on the board... Sorry for the bad photos though...
Do you think the little dent in the CAP can cause the BK act up?
Alien...
tc3_racer_001
tc3_racer_001's Avatar
08.07.2008, 06:03 PM
pehaps, how hard would it be to replace it? if its easy i guess you could try replacing both of them with suitable ones or perhaps bigger ones!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
ANGRY-ALIEN
08.07.2008, 06:27 PM
Hi tc3_racer_001,
I think I can change them, I'll see if the electronics stores have any that may be suitable for the repair...
Hmm... With that said... What would be a suitable replacement?
Alien
ANGRY-ALIEN
08.09.2008, 08:09 PM
Hey tc3_racer_001
The caps did not change anything... Do you or Anyone else have any ideas? I don't want to just loose the controller...
ANGRY-ALIEN
08.15.2008, 02:01 AM
Okay guys, should I give up on this controller?
Alien
