Minimun amp rating of and esc for 2s & CMS7700
Gee
A Horse's Ass
Gee's Avatar
Minimun amp rating of and esc for 2s & CMS7700 - 08.04.2008, 01:49 PM
To match up an inexpensive esc with the cms7700 motor on 2s. What would be the min amp rating of the esc to look for?
Mister-T
08.04.2008, 02:35 PM
This one suck current like russian drink vodka. Mamba max is the cheapest solution out there. If you don't like it try Speed passion GT or Tekin R1pro
Gee
A Horse's Ass
Gee's Avatar
08.04.2008, 04:47 PM
Thanks. I still would like to know what the minimun amp for an esc could be. What's BrianG been doing lately?
This should be on his calculator web page under the heading 'All the crap that Gee doesn't know how to figure out his self." That would not be a small page either.
I'm sure BrianG page has all the information I need to get my answer. Just don't know how to.
mriccucci
mriccucci's Avatar
08.04.2008, 05:45 PM
The amp draw depends on the load placed on the motor by what you've got it in. So you cant really know unless you put a meter on the system and find out.
83gt
08.04.2008, 06:10 PM
I'm not sure, but I do know the 7700 is a hog. The MM esc will get quite warm while pushing any 1/10th off-road with the 7700 motor. 1/10th on-road might be ok. I'd guess you'll be in just under the 100A range pretty easily if it's in a decent sized vehicle, but that's a wild guess.
Like mriccucci said, it depends a lot on the application and load on the motor. Perhaps if someone is running a similar setup as you will be running and is using the same running gear you can get some input from them. We'll need to know what your plans are though.
J.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.04.2008, 06:13 PM
Sounds like a job for the MGM 8012!
Gee
A Horse's Ass
Gee's Avatar
08.04.2008, 07:28 PM
Okay, I guess I will have to give it up. I know there's better setups and the villian isn't stable at higher speeds and all the kinds of different motors that would be better. But I am not asking of those questions. Just so I don't get bombarded with post telling me which boat would be better or what not. I think you know what I getting at there. Just looking for what min amp esc to run in this configuration.
Here is what I am working with because it sitting here not being used. 2 - CMS7700 motors. Villian IV and 2s batteries. I was searching for 2 inexpensive esc to run in the villian. I came across these esc and I liked the features and water cooling built in. The prices are not that bad either. I would be getting water cooled jackets for the cms7700's and keep the villians gear boxes to adjust the setup with different size pinions. Ofcourse I was hoping a 25amp esc would get by in the setup.
http://www.himodel.com/electric/Seak...ng_system.html
They also have a 35amp and a 60amp esc.
So with the setup what do you think about the amps.?
83gt
08.04.2008, 07:52 PM
Aha, and now we get to the point! Discussion could have been much more accurate if you had mentioned you were running this setup in a villain to start with. There can still be no definitive answer as to what amps you'll be pulling, but a 60-70A ESC might very well be OK, if it's decent quality. Cooling won't be so much of an issue, and load should be relatively low compared to 1/10th off-road.
J.
Gee
A Horse's Ass
Gee's Avatar
08.04.2008, 08:14 PM
My bad. I'll will be more up front in my questions from now on. I just didn't want to get all the responses telling me the othe motors I should use, or scrap the whole thought and get the SB27. But then again this is RCM. That don't happen here. No matter how whacked out our projects can get. We're all supportive. Family, gotta love em. Thanks for the help.
So it sounds like a 60amp would be a minimum to try. Any thoughts on the type of esc I linked to?
08.04.2008, 08:23 PM
Exactly. The best you can do is figure out the minimum possible current (0A when off ), and the maximum possible current (very high current at stall). The running current will be somewhere in between.
Not trying to sound sarcastic, it just depends greatly on weight, gearing, etc.
Gee
A Horse's Ass
Gee's Avatar
08.05.2008, 01:55 AM
Didn't take is that way brian. I suppose using too low of and amp esc would just burn the esc up. If I remember correctly. Running at half throttle is actually worse on things then running at full thottle. So even thinking I would not need full throttle with that setup. Still doesn't get me in the cheaper seats.
How about....
It sounds like you guys feel the load would be lighter then a rustler for example. If I am running two motors and two esc to push this thing. Using a low gearing setup for each motor. That should help lighten the load that is put on each motor. Right.?.? I'm sure my math isn't going to work here. If each motor would be doing half the work. I could take the 70amp esc that I might get by with and divide that by two and run two 35amp esc. What are the odds the esc(s) would last until the LVC cut in for the lipos?
tc3_racer_001
tc3_racer_001's Avatar
08.05.2008, 02:17 AM
id say just buy a sidewinder, add a fan, ubec and capacitor and call it a day... it MAY work great, but i dunno, seems to run the 5400 max... but with a ubec and capacitor it would take the load off, and you would have programming options :)
OR spend the money on the Mamba max esc and not worry about it blowing up, but that isnt cheap i know! (cheaper than buying a cheap esc for $50 then buying a mamba max when it blows up )
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Gee
A Horse's Ass
Gee's Avatar
08.05.2008, 03:20 AM
I have the mm's (not laying around their in other rcs) I could put in it, but then I would need to try and water cool them also. That's one of the reason the model of esc that I linked to above was appealing to me. They had the water cooling already set up. Has the fwd/rvs brakes, and can handle the 2s lipo. The cheapest one, the 25amp is only 32.00. So blowing up two of them wouldn't be that expensive. If it is a sure fire explosion running the 25amps. I wouldn't get them. If the odds are 50/50 or better that a 35amp esc might not blow up. I might gamble the 84.00 dollars for two of them. Once it starts getting into the 120 dollar range. That's a little different for some reason to me.
The sidewinder didn't come to mind for an esc to use. Two of them would be a bit of money plus the water cooling for them. I did notice last night when I was on the cc looking for amp info. They don't recommend the sidewinder with any of their motor above the 5700. I guess that should of have given me a better clue of what I was getting into.
This was just an idea to throw in the villian, make the long trip to the lake and try it. I rarely get a chance to run it now. If I lived on a lake or was at one alot. There wouldn't even be an issue about what to get for it. The best I could afford.
tc3_racer_001
08.05.2008, 03:45 AM
why not try 2x mamba max and 2 batteries and use a y adapter? im not even sure how the steering works on those boats though (whether it decreases one prop or has a rudder)
also i forgot u were using a boat LOL.
but the mamba maxxes shouldnt get too hot inside a boat, perhaps adding a alloy sheet that they stuck to would be a good idea?
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
hemiblas
hemiblas's Avatar
08.05.2008, 11:59 PM
Ok, I'm going to go out on a limb here and I'm going to say a 120A speed control or above. The 25amp unit will melt. The 7700s pull some serious amps. I generally have to gear way down just to get the mamba to 180 degrees on my offroad vehicles. In my opinion the 7700s are for on road only. At 2S you are looking at 56k rpm about double what a boat would normally pull. I think you are going to smoke some esc with this one. I think the 7700's will work on 3 or 4 nimh cells each. The villain also doesnt have any prop choices so you are stuck with whats on it right now. The only way I think you could get it to work is if you could prop way down. If you can gear it to about half of what the titans normally geared at you may have a chance on this one, but even at that I would recommend an 80A speed control min.
EDIT.
check out the cheap esc thread. They have 100A speed controls for 28 bucks.
EDIT
I'm a big fan of my villain since the last time I took my supervee to the lake the water was to rough to get on the plane.
