Baja 5b Conversion "Prep Work"
Takedown
WARNING: May become violent.
Takedown's Avatar
Baja 5b Conversion "Prep Work" - 08.16.2008, 06:44 PM
Been thinking about this idea from the very start of my save for a 5b. I should be able to finally purchase it this weekend or next week sometime. Ive seen my friends 27cc grizzly run and its a beast for sure. Only problem is that my neighbors hate the extremely loud setup he has. "Xcan pipe with 27cc engine". Im looking to possibly convert my 5b. I have the Sentileon 100a HV ESC set to order whenever I get around to ordering the 5b and I also have my mind set on The white lipo packs from UH that have are 5s 4800mah 25c-35c. I plan on running two in series. That should be enough for that but Im stuck on a motor.
Heres what I had in mind...
Keep in mind that a normal max rpm range for 23cc-28cc 2stroke gas is 10k rpms. The outrunner has 250kv. Take 250kv x 37volt nominal and you get 9250 max rpms. Plus this motor has a 50-70cc 2stroke gas equivalency which should be plenty of power.
So the setup will be...
ESC- Sentileon 100a HV
Battery- Two 4800mah 25-35c 5s Lipo's
Motor- HXT 80-85a 250kv Outrunner
What do you guys think.
RIP- Tammy (9/14/08)
brushlessboy16
brushlessboy16's Avatar
08.16.2008, 07:41 PM
i tried to tell you, now you listen
:D
put the order in for my Monster max
Takedown
Takedown's Avatar
08.16.2008, 08:34 PM
Im not 100% sure yet ben. Have you ever driven a 1/5 gas? Its an adrenalin rush for sure.
Takedown
Takedown's Avatar
08.16.2008, 08:39 PM
I doubt I'll do the conversion because I've still got the matrix to finish but this is just an idea if I get fed up with gas which I doubt I will. Ive ran a 1/5 27cc XTM grizzly and its really a cool experience. Can run up to 45mins on a single tank of gas and you never have to wait to run it. I think Im going to do my Matrix TR FRE instead right now. Converting the 5b isnt a need and converting the Matrix is.
bl-is-future
bl-is-future's Avatar
08.16.2008, 09:21 PM
Sweet cant wait to see this done. I think that setup will do fine in there. That is one power packing motor
Takedown
Takedown's Avatar
08.16.2008, 09:59 PM
If I can get enough people intersted in this build I may just do it for the hell of it seeing that you guys are interested in it. I am a little more intersted in finishing my Matrix conversion first though.
BlackedOutREVO
08.16.2008, 10:44 PM
I vote for the 5b. Theres enough of everything else. Theres one other BL 5B here I think
killermmn
killermmn's Avatar
08.17.2008, 12:21 AM
http://www.castlespecialprojects.com/csp_90_volts.html
take 200 amp and you goood to go!!
Byte
08.17.2008, 04:38 AM
I'm thinking to build a E-baja to, but I haven't got enough money yet. Some one here on the forum already has a E-Baja, and someone is building one ( With Mike ).
Look here: http://fastestrc.blogspot.com/search/label/baja
He has a NEU Motor, and also on this forum.
Good luck!
bl-is-future
08.17.2008, 11:35 AM
takedown i am really interested in a 5b convert. I would do one myself but lack funds. As soon as i get a god chunk of cash though the gas 5b will at least be purchased then i will convert it when another chunk of cash comes along.
Takedown
Takedown's Avatar
08.17.2008, 12:45 PM
Hmmm... When I buy the 5b either on monday/tuesday or wednesday this week Ill see if I can put an order on the motor and the ESC. That way I will not be able to change my mind on this seeing that Ill try to many times. I still have to see what Im gojng to use for a motor mount. Im thinking .50in tempered plexiglass 12x12 sheet off ebay for $20. The main think Im worried about is the burst current draw from the giant outrunner. If I gear it just right hopefully it wont try to draw more than 150a cont otherwise my lipos are screwed... If you guys have any suggestions please let me know.
Takedown
Takedown's Avatar
08.17.2008, 01:00 PM
Ok I think Ive made up my mind on this. I will order the Sentieon 100a HV ESC along with this outrunner... The reason I want this one over the bigger purple one is that its half the cost and has a better quality rating.
Its a little less power but in my opinion on 10s it will be plenty for my likings.
brushlessboy16
08.17.2008, 01:05 PM
is there even such a thing as tempered plexiglass?
why not the 80-100
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
08.17.2008, 01:16 PM
I've always thought that outrunners aren't as efficient as inrunners, or am I mistaken?
Takedown
Takedown's Avatar
08.17.2008, 01:19 PM
why not the 80-100
I call it tempered plexiglass because it doesnt shatter as easily as normal plexiglass does meaning it has some flex.
Sleebus- Outrunners in general are more efficient than inrunners.
