08.18.2008, 06:39 PM
What happened is that I got a MGM and a 1512 1YF. The mm esc is on the shelf for now. I also bought a v1 mmm esc that I am waiting for repair.
azjc
08.18.2008, 06:51 PM
It is set to a low setting, I don't recall the value off the top off my head, but I will check later today. MY timing is set for 5 so maybe I will try to bump it up to between 8 and 10 and see what happens.
the Neu delta winds like the lowest advance possible "0" the wye winds you can go up to 10, I think your pack isnt up to snuff, I dont have any expierence with the Elite brand but if you may want to try a quality brand (Polyquest, Neu, Flightpower/Thunderpower) it sounds like your motor is asking for more power when you go WOT and the pack cant deliver...the 1.5d is a amp hungry motor
highflier
Emaxx- FLM wannabe
08.18.2008, 07:14 PM
I would try an to use a seperate receiver pack just to see if it resolves the issue.
or Could it be LVC??
Highflier
E-maxx Brushless
HPI MT Racer Brushless
Associated rc10t brushless
Associated B3 Brushed
Tons of airplanes and a few Heli's
08.18.2008, 07:16 PM
I think it has internal issues...
azjc
08.18.2008, 09:12 PM
Highflier
if it is the LVC that would be a problem with the pack...it wasnt holding the voltage like it should setting off the LVC
