Geogenesis13
RC-Monster Ruthenium
Geogenesis13's Avatar
08.18.2008, 08:00 PM
no they aren't from maxamps they are from thunderpower
"Its a bird."Its a plane.""It is my E-Revo and bl 5T you idiots."
Geogenesis13
08.19.2008, 10:05 PM
would the poly rc 3s 5000mah30c batts work and fit inside the compartments
ah-see
08.20.2008, 12:12 AM
Geogenesis, do some thinking for yourself. I'm sure you don't need your hand held to go to the toilet, so i'm sure you can figure out if the polyRC packs will fit into the e-revo.
08.20.2008, 06:27 PM
It is indeed a matter of common sense. The dimensions above are accurate, so it will be obvious if any given pack will fit or not (a 30mm high pack will fit (just), a 31mm high pack will not).
This aint the traxxas forum anymore, a little more free- thinking and experimentation is called for to figure out ones own questions, especially when they are such simple ones.
Geogenesis13
08.20.2008, 10:42 PM
okay i get that but i just want to know how a 3s 4500mah 30c pack is longer than the 5000mah 30pack
tc3_racer_001
tc3_racer_001's Avatar
08.20.2008, 11:44 PM
the 5000 is most likely taller.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
ah-see
08.20.2008, 11:56 PM
Think of battery capacity like water in a bottle. You can have a liter of water in bottles with different shapes and sizes, but the volume is still 1 liter. Same thing applies to battery capacity. Lipo capacity and volume are directly proportional in most cases when talking lipos.Try to understand what i have said and it will all become clear.
08.21.2008, 01:03 AM
So how do maxamps packs always seem to be smaller than the comparable spec enerland cell based packs? (this is sarcasm)
What you say is quite true, however reformulation can lead to smaller cells of the same capacity. Just another way that I know that maxamps specs are bogus....
Geogenesis13
08.21.2008, 10:11 PM
allright i see what you mean so should i know about anything else
