Record of MMM V2 success so far
joeling
joeling's Avatar
Talking Record of MMM V2 success so far - 08.24.2008, 07:58 PM
Gents,
With a few threads reporting the failure of MMM as such, I feel that we should also gauge the success rate of the MMM. Let the (hopefully) silent majority speak out on your success with V2 so far. Some info like :
1) What configuration ? (vehicle, motor, battery)
2) Any mods ? (external BEC etc.)
3) How long the run time so far ?
4) Driving style (sissy or barbarian)
5) Any other relevant info
would be cool. Mine is on the way so let's hope it's second time lucky
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
auto2
08.24.2008, 08:23 PM
my v1 and v2 are working as advertised. i use for racing only. hours on the v1 and maybe 5 packs on the v2
15152df in a 808 mmmv2 stock ou t of the box
15121.5yf in an xt8 mmmv1 with bec
TruckBasher
TruckBasher's Avatar
08.24.2008, 08:31 PM
im interested on this thread...subscribing...
E-Slayer direct drive to diff
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.24.2008, 08:51 PM
3905 E-maxx, 6s flightpower, tekno neu 1515 2.5d
Virtually stock except for futaba fasst controller
around 1.5-2 hours on it total
bashing, medium to hard running
Great success so far and no complaints. I am running with the internal bec and all is well.
www.cubicle101.com
Finnster
KillaHurtz
Finnster's Avatar
08.24.2008, 09:07 PM
Hyper ST truggy, 5S zippy's, 1515 2.5D.. ~1900W as geared.
So far everything but the custom lvc works. Motor, batts and esc stays cool. ~2hrs of hard bashing so far. Everything so far is good temp wise. Motor under 150F.. esc..hard to temp. ;) Fan comes on for ~30secs when I stop it then goes off. Guess that's a good sign.
bdebde
That's All Folks!
bdebde's Avatar
08.24.2008, 11:08 PM
Muggy, 1515 2.5D, 6s
No mods, running it right out of the box
about 4hrs. run time on it
hard bashing, full throttle runs, wheelies, small jumps (so far). Trying to see if it can take a beating basically.
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
08.24.2008, 11:19 PM
1) What configuration ? E-Revo, Tekno Neu 1515/1Y, TRC 4s 15C 8000, and Zippy 6s 20C 4300
2) Any mods ? not really just a plate in case it flames;
3) How long the run time so far ? about 10 hours
4) Driving style. I drive like a sissy...lol...would anyone? I beat my MMM like a red-headed stepchild!
5) Any other relevant info. Not that I can think of...
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
08.24.2008, 11:31 PM
I suppose my V1 info may not be relevant, but then again, maybe it is?
1) What configuration ? (vehicle, motor, battery) Hyper 7, 10XL, 6S A123
2) Any mods ? (external BEC etc.) Nope
3) How long the run time so far ? Several hours
4) Driving style (sissy or barbarian) Barbarian++
5) Any other relevant info: I can't seem to keep fans running in it. I think I've been through at least 4 by now. I've had one blade break, the rest have been electrical failures.
08.24.2008, 11:38 PM
This info is for my v1 that has about 2 hours on it so far:
1) What configuration Erevo, all stock save for mgt 50t spur, 19t pinion. 4s lipo, neu 1515 1.5d.
2) Any mods ? (external BEC etc.) Added some high density foam cushion between the case mottom and the pcb, clearanced the case botton for the fan plug, and enlarged the slot in the case side where the signal/switch wires exit. I plan to add so shrink tubing to those wires and the internal fan wires. I recently purchased a used MMM v1 that had run quite a bit, it had frayed wires on the fan and where they exit the case, the fan plug had also scratched the case bottom alot. Should have taken pics, but just sent it to castle...
3) How long the run time so far ? 2 hours+
4) Driving style (sissy or barbarian) Fast street runs, lots of full throttle and hard brakes. Also ran off road, and on a ginat asphalt hill (mountain?!) A fair amount of jumping. I know how to drive so I am not as rough as some...
5) Any other relevant info: Case design is poor, IMO. It should have some sort of pcb support, other than the lower case. Some plastc tabs and screws would be best. The sticker on the bottom does not stick very well, also the tabs on the case bottom are poor. I have heard about fan clearance issues, and will check my V1 for this. Fan still works fine, it is on all the time being a v1 model. Signal wire exit hole is also poor, should have a runbber grommet, or some sort of wire protection. Internal fan wire also needs addl protection from rubbing the side of the pcb. Honestly all of this shows very poor physical testing... CC needs to do a bit more of that next time...
I will say that the performance has been great. No issues at all with running the motor and the internal bec works flawlessly so far. I have a V2 coming this week and will have it in a LST on 6s, will report back after some testing...
jnev
jnev's Avatar
08.25.2008, 12:09 AM
1) What configuration?
Losi 8ight, MMM V1, Tekno Neu 1515/1y, Hyperion 4s 5350mah lipo pack
2) Any mods?
Completely stock V1 MMM ESC... nothing done to it. The fan doesn't seem to work, but it was like that when I bought the ESC used. The temp of it doesn't go above about 120*F so I'm happy with it.
3) How long the run time so far?
I have about two and a half hours under it, and probably more with the previous owner.
4) Driving style?
Testing was pretty conservative, then I did some full speed to full brake runs for about 10 - 15 minutes straight. And today I had about a hour and a half bashing session with some massive jumps and big hill climbs, but I wasn't working the ESC too hard. It was a lot of stop and go though.
5) Any other relevant info?
It is running perfect for me so I can't be happier.
kulangflow
Never Fast Enough
kulangflow's Avatar
08.25.2008, 01:12 PM
MMM v1
1) What configuration ? Revo, 5s, Medusa 60-1600
2) Any mods ? None
4) Driving style ? Barbarian bashing
5) Any other relevant info ? Never ever gets hot. Runs like a champ. Recently sold it to a friend who will be joining RC-M soon.
MMM V2 arrived this morning! Thanks Mike!
Procharged5.0
Procharged5.0's Avatar
MMM V2 arrived this morning! Thanks Mike! - 08.25.2008, 01:21 PM
I'll post results on operation first chance I get.
Edumakated
08.25.2008, 02:07 PM
Originally Posted by joeling View Post
Gents,
Regards,
Joe Ling
1) RC8, Neu 1515 2.5d & 1512 3d, 5s 4000/5000 Zippy Lipos
2) Dremmeled fan grill from case, removed switch, and added padding in case. I run a Novak 30mm fan off the receiver.
3) Three races and about 2 hours of driving time on the street
4) Barbarian... I always go big
5) The stock fan broke in the first two minutes I had it running on the track. Same problem as before, the plug breaking on the bottom of the ESC.
Overall, working perfectly. Temps around 140 after a 10-15 minute main pushing it hard.
My v1 is working flawlessly too. I just removed the top of the ESC case and ran it with no fan. I think I have 5 or 6 races on that one, including a 30 minute main that it took with no problem (no fan either). Temps in the 150-165 range with no fan.
phatmonk
RC carbon junkie
phatmonk's Avatar
08.25.2008, 08:09 PM
Losi 8T
MMM V2 1 hour
Tekno Neu 1515/1.5D/F
4S 6000 Maxamps
Cen Matrix FRE
MMM V2 1 hour
Neu 1512/1.5D/F
3s 6000 Maxamps
I took the 8T out to the pavement and did some speed runs and practicaly could have shreed the tires off the rims.Its stupid fast.The Matrix is also equaly way overpowered.The MMM V2s so far are performing as they should AWESOME!!
kulangflow
Never Fast Enough
kulangflow's Avatar
08.25.2008, 09:47 PM
MMM v2
1) What configuration ? Revo, 4s, 9XL, 24/65
2) Any mods ? None
3) How long the run time so far ? 30 minutes
5) Any other relevant info ? Stayed nice and cool after 30 minutes of bashing
