Had an EPIPHANY during math class today -
08.27.2008, 04:05 PM
So there I was, sitting in a two hour lecture on infinite sequences/series by a British professor (funny guy!), and all of a sudden this hit me (attached):
08.27.2008, 04:12 PM
I don't get it, nice shading though
08.27.2008, 04:20 PM
i see a slipper on the outrunner
WARNING: May become violent.
08.27.2008, 04:23 PM
I also see a slipper setup on the outrunner but whats with the two shafts, diff and a solid gear?
RIP- Tammy (9/14/08)
08.27.2008, 04:27 PM
Correct! It's actually two separate ideas, but I didn't want to draw two motors.
The top is in fact a slipperential with the slipper on the outrunner shaft and that drives a center diff.
The bottom is just a solid shaft.
I will have to explain myself later, for now I gotta get ready for work.
oh okay. why not just run direct drive :D
08.27.2008, 04:54 PM
Maybe he wants the nitro spool up feel.
08.27.2008, 05:13 PM
so the out runner fits in the transmission, like on a revo
08.27.2008, 06:03 PM
With a geared setup you can maintain the center diff, use a slipper, and also use an outrunner that may not have the optimum kv for your intended battery and desired top speed. A smaller higher kv motor could be used with a smaller "pinion" on the slipper than the center diff "spur" (like a 36t revo spur on the slipper driving a 46t spur on the center diff)
08.27.2008, 07:23 PM
So basically, more gearing options. That was one of the things I didn't like about outrunners; you had to make sure to get it right because there are so few ways to adjust gearing
08.27.2008, 08:15 PM
Interesting...well one good thing about outrunners is they promote innovation and not just traditional stuff...
I am yet to find out if it is innovation or just heartache of wasting time/effort
08.27.2008, 08:59 PM
IIRC, Patrick (pdelcast) made the apt comparison:
Two pole motors are like import 4-cylinders. They have high rpm/horsepower, but less torque. Neus are like domestic V8's, lots of hp and torque. And outrunners are like diesels with lots of torque but don't like the higher rpms.
I'm too lazy to go find the post, but it's along those lines.
Yip Yip Yip...
08.27.2008, 09:01 PM
So is your idea putting the slipper on the pinion instead of onto the diff? Something like the LST slipper would be good for that as it seems to be able to handle power.
08.27.2008, 09:14 PM
Very well said Brian!
08.27.2008, 10:16 PM
Agreed spot on Brian....even in pricing they seem to be the same as your comparison....and even what I said innovation....most diesel engine can now run biodeisel or veggie oil
Linear Mode
