Further review!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
Further review! - 09.01.2008, 04:12 PM
I have now geared my 1515 2.5d Tekno Neu up. 56/25 is a bit much for this combo on 4s but temps after 5min where great. ESC 107*, motor 121*, Lipos 105*, with an ambient Temp of about 87*. However performance was poor and top speed actually seemed to suffer. I changed the gearing to 62/25 which gives me a bit more top end than the 54/20 and still has plenty of low end. This is giving me about 35MPH which is plenty to have fun with till I upgrade to 6s. Overall - Very happy with this motor, glad I didn't fall victim to another Feigao.
big greg
09.01.2008, 06:24 PM
hmmm your batteries must not be able to keep up, otherwise you should have had a rocket
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.01.2008, 06:47 PM
I may have needed to adjust the punch control for that gearing, I currently have of set at 80%. Although they are MA packs I'm quite sure they where keeping up, 6000mah packs and barely warm. Either way for me I'm pretty happy with 35MPH. I may try regearing again and adjusting the punch. I'd also like to get the 58t spur and see how that works for me.
big greg
09.01.2008, 06:50 PM
yea that is alot of punch control, but that should not have affected your top speed, esspecially if your geared up
azjc
09.01.2008, 06:51 PM
I have found that disabling the punch control and using the throttle curve adjustment works well...gives you good control will still keeping the snappy performance
blueb8llz
09.03.2008, 04:54 AM
ive never tried that. so how do you have your throttle curve set? hows it look like
azjc
09.03.2008, 07:27 AM
it starts in the lower left hand corner of the graph and goes laterally for a little than I start to cuve upwards slightly than its a straight line going in the direction of 2 O'clock
blueb8llz
09.06.2008, 02:33 AM
laterally means horizontal line correct? so you start in the lower left corner then move up like a millimeter, then horizontal line for 1/2 inch, then straight line in the direction of 2 o clock?
