AutoXMan
09.08.2008, 05:50 PM
m11 are expensive as Hell, and any rx will work as long as its the same frequency. the only problem i see that the rx that comes with it has "s" connectors where the power and signal wires are flipped- might use my current rx
Be careful I am 99% positive you cannot use any reciever with the Airtronics transmitter. Remember there is positive and negative shift rx's and not all are compatible.
brushlessboy16
brushlessboy16's Avatar
09.08.2008, 05:57 PM
easy enought to switch the wires on the connector..
AutoXMan
09.08.2008, 06:03 PM
I am not talking about the servo leads, I mean the same reason you cannot use a Futaba RX with a JR transmitter.
brushlessboy16
09.08.2008, 06:41 PM
i dont follow.
brushlessboy16
09.12.2008, 03:32 PM
I think this deserves a new post :D
works great, only thing is my lipo that i got for it dont fit... anyone need a 2500mah 3s lipo?
Takedown
WARNING: May become violent.
Takedown's Avatar
09.12.2008, 04:36 PM
Bout time for a better radio eh?
RIP- Tammy (9/14/08)
brushlessboy16
09.12.2008, 04:53 PM
ehh maybe, took me untill now to get it setup how i want it
Takedown
Takedown's Avatar
09.12.2008, 05:16 PM
I was the same when I got my first good radio. Its a big leap from standard am and fm setups...
brushlessboy16
09.13.2008, 12:56 PM
Some more pics, and yes the m8 does work with futaba rx's :D
Takedown
Takedown's Avatar
09.13.2008, 01:55 PM
Looks good. Still needs a rechargable TX pack.
tc3_racer_001
tc3_racer_001's Avatar
09.13.2008, 06:43 PM
problem is, ive had range issues using nimh x8 so i had to use 9x nimh to fix this (i had dead energizers which wouldnt hold their voltage.)
lipo = best option. u could do it if you can cut out that plastic bit and move anything which is housed in it at the moment, u may need 2 flat packs as the pack ive got is like a square (cost $16 from HC)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
brushlessboy16
09.13.2008, 07:07 PM
i dont know if i want to tear up the controller at the moment
tc3_racer_001
09.14.2008, 01:31 AM
not hard to undo a few screws to see if theres anything important in the way. then u can re-assess the idea.
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
brushlessboy16
09.18.2008, 07:45 AM
i tried... and failed- tried to make as much room as i possibly could, lipo was just tooo wide. so i ended up making an extension for the power connector inside the controller and mounting the lipo on the front portion of the radio's foot.. i know its not the cleanestsetup bbut it works like a charm
My latest dilema is battery placement..
Right now with the battery far back it makes for great wheelies but horrible handling
A few options..
-mount the battery inlin with the chassis, the back resting agains the motor plate.. it moves the weight to the center of the truck and further forward.
-Mount the battery on the front of the truck, in front of the pinion and spur gear on top of the tvp's. weight is further forward by a longshot..
anyone have any input?
