auto2
09.09.2008, 09:20 AM
i would think if the software is "locking up" like a windows pc flashing it and starting from scratch should fix it? did you try that?
JaySki
JaySki's Avatar
09.09.2008, 09:22 AM
Originally Posted by TruckBasher View Post
Now that you mentioned it the first few packs on my modded V2 run fine until I change the LVC to a custom 1 and change the brake amount...after that I was able to run it for 15-20mins then it just stop working after serious cogging in forward and reverse....
Not sure if it make sense...not sure how the software affected the HW ...
That is seeming to be the trend....
jhautz
jhautz's Avatar
09.09.2008, 12:30 PM
Weird thing I was just thinking about when I read this.
I recently had 2 MMMs die on me. A V1 and a V2. I had one of the first 50 or so V2 MMMs that were shipped with the 1.18 software on it. Apparenty it had some sort of LVC program error that didnt cut off the LVC unless you were at less than 1/3 throttle. I read about it on the CC website. They said there were only 50 or so that got out with that version software and the rest were shipped with 1.19. When I read this I checked and found 1.18 on mine so I updated it to 1.19 and the next time I ran it, it died. It only had one race day on it but it had been working perfectly up to that point, and I never got even close to the LVC so I didnt see any 1.18 problem. Didnt really think about it untill jsut now, but I wonder if the software had anything to do with it?
I also had a V1 that was running 1.17 and had close to 20 hours of run time on it and was still working well. I updated it to 1.19 at the same time and it died the next time I ran it also.
I have one V1 left. It still has 1.17 software on it. I am not going to touch it. I has a good 10-12 hours of runtime on it and its still going. I dont know if the software had anything to do with it, but at this point I'm not going to introduce it as a variable. Its working as is. I'm leaving it and I guess I'll se what happens.
to make it...
or break it...
Silent...But Deadly
phatmonk
RC carbon junkie
phatmonk's Avatar
09.09.2008, 05:22 PM
Wow I updated both my MMM v2s and have run 1 of them and had no problems.But that might be a problem.Is Thomas from CC in his new thread about the failures asking what software version people are running.
jhautz
jhautz's Avatar
09.09.2008, 07:00 PM
Could just be coincidence, but it just struck me funny that they both went right after the software upgrade is all.
to make it...
or break it...
Silent...But Deadly
pasan
I <3 RC
pasan's Avatar
11.15.2008, 06:29 AM
I just saw today that mine too is a 1.18, and I have run it through at least 10 packs on 6S without any problems at all. I upgraded to 1.20, and honestly I'm a bit scared to run it now :(
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.15.2008, 06:54 AM
Run it, has better throttle and no issues
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
pasan
I <3 RC
pasan's Avatar
11.15.2008, 07:39 AM
Just came back from running both my MMM powered E-Revo and MM powered E-Maxx, on 6S and 4S respectively. You're right about better throttle response, I tested this out on the E-Maxx and cogging is a lot less apparent on the 7XL. I didn't see any noticeable operating difference in the E-Revo but then I pretty much drive that thing like a 'tard anyway (why else would we run those things on 6S? :D) how ever, the motor seems to run quite a bit cooler now, and the ESC fan didn't nearly operate as regularly as it used to.
e-mike
e-mike's Avatar
11.15.2008, 01:34 PM
me too ive noticed that...i have 5 unit(v3)and the fan come to life at 95F and for a other one unit the fan begin to spin at 125f!!...(both esc had exactly the same set-up)why?????
D8t on juice!!
Pdelcast
Pdelcast's Avatar
11.16.2008, 02:21 AM
Well... several reasons. 1st, the calibration routine for temperature is run on the very first power-up of the MMM (which is at our lab in Kansas) -- but the temperature can vary by a few (maybe 5) degrees in the lab (depending on if its a hot day, or a cold day outside...)
2nd, the temperature sensor itself has a few degrees of tolerance.
That's why we set the temperature to a fairly low turn-on temperature. The MMM can run up to 120C (250F) on the heat sink during normal running with no issue at all, and can run up to 200C chip temperature (close to 400F) before any real internal damage starts to happen. We often reflow the solder on the transistors during extreme power testing, (where the solder becomes liquid under the transistors) and in most cases the MMM just keeps right on working normally (until the processor clock shuts down... that happens when the processor internal temperature gets to about 180C -- but that can take a few seconds for the heat to conduct to the processor core. If the processor shuts down, everything just cools off and it restarts a few seconds later, with no issues.)
For production units, we set the shutdown temperature (thermal) at about 90C-100C (about 195F-210F.) I haven't heard of anyone (yet) thermalling a MMM. (let me know if I'm wrong about that!)
Patrick del Castillo
President, Principle Engineer
pasan
I <3 RC
pasan's Avatar
11.16.2008, 03:05 AM
I ran the truck again today, and the fan definitely comes on a lot later, and the MMM is quite warm to the touch before the fan comes on. I haven't any kind of thermometer to properly verify the temps, however I'm adamant that the unit runs warmer for longer before the fan spins up. Might this be a sign of a failing fan/thermistor?
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
e-mike
e-mike's Avatar
11.16.2008, 12:20 PM
thanks....pdelcast...now i know whyim reassured
D8t on juice!!
