View Poll Results: Status of your MMM v2
Working Normally 57 47.50%
Failed 46 38.33%
Failed violently, potential safety concern 17 14.17%
Voters: 120. You may not vote on this poll
09.15.2008, 06:05 PM
Fan mod is simply a teflon washer superglued into the middle of the fan case.
IMG: Care of Jeff
The heatshrink is on the fan lead to avoid it rubbing against the PCB.
Originally Posted by CRTIM View Post
wow...finally a post that gave me some hope for finishing my build and trying my MMMv2 out ....can you tell me what bec's your using ??
...and more about the fan mods you did ??where does the heat shrink and washer go ?
thanks for your help
e-mike
e-mike's Avatar
09.15.2008, 06:07 PM
why add a washer at this place....??????
and do you remove the foam on the lid and make a groove....???
D8t on juice!!
big greg
09.15.2008, 06:10 PM
so it rubs in the moddle of the fan, protecting the blades
Darion
09.15.2008, 06:48 PM
After running my 2s packs for about 4 hours of run time I ran a 4s 25C 5000 Poly RC pack through my MMM with no issues. Ran the truck hard for about 12 minutes ESC temp measured 120 motor temp was 155. Trucks gearing is 16/47 with the Savage trans locked into second. It was only one pack at 4s but great none the less.
Darion
CRTIM
09.15.2008, 08:14 PM
thanks arct1k for the pic and info
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.16.2008, 12:39 AM
I still haven't had no issues with my fan. Still might look at doing this washer mod though
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
starscream
RC-Monster TQ
starscream's Avatar
09.16.2008, 03:01 AM
My V2 stopped working after 10 min.
6S NEU 1515 2Y in a mugen MBX5
Yes, this is Dafni's old faithful but unfortunately, old faithful's maiden voyage was cut short by the dreaded bec bug...
Now if only I knew how to perform BrianG's bec mod......
Ha Ha
Dafni
Dafni's Avatar
09.16.2008, 03:10 AM
Even Old Faithfull could not lift the MMM curse...
Mad Max
09.16.2008, 09:29 AM
My V2 Monster died silently after about ~20 min total runtime on 6s.
Now it just started it's second life as a MMM V2 lite (BEC removed, thx to BrianG).
So far everything looks well, but I have no real runtime on it so far.
XT8 - Neu-Castle 2200 KV - MMM V1 - 5S
eRevo 5605 - 11XL - MMM V2 lite - 6s
lucias
lucias's Avatar
09.16.2008, 10:27 AM
I let a friend borrow my V2 that was int he box when he got it.. He said he made it 3 packs before it died completely.. He was running it on 6s, it would turn on then die a couple of times and then there was nothing.. he burnt the BEC out of his V2.. My V1 I have been running on 5s for multiple packs.. the only thing that I have had go bad is the fan stopped working so I strapped a 5v fan out of a blade server that keeps that thing way cooler than the stock fan.. no problems with it other than that..
If I unplug the motor should I have to re-sync my radio? I did have the happen and didn't know if it was normal...
e-mike
e-mike's Avatar
09.16.2008, 04:26 PM
dammmm... now more died thant alive
D8t on juice!!
coreyfro
09.17.2008, 03:04 PM
On paper, this thing is SOOO AWESOME... I just can't wait for the device to catch up.
The switching BEC is the primary reason I selected this device. I would like a single part to handle this all. I want a device that handles all power for all devices. I'm using this in a simple robot, and the brain requires clean power. Now I might need to reconsider my strategy, but wanted this nice and simple so that other people could follow the instructions easily and get to the important stuff, programming the brain.
JaySki
JaySki's Avatar
09.17.2008, 06:44 PM
WTF?!?!
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.18.2008, 11:55 PM
My number 5 seems to be working perfectly with an external bec.
jayjay283
jayjay283's Avatar
09.19.2008, 12:38 AM
got my pillow balls from tower today, fixed up the maxx and fired up the V2 on 5s after a 4 day break, Still loves me 32 hours strong
