Takedown
WARNING: May become violent.
Takedown's Avatar
10.09.2008, 07:12 AM
No I meant exactly as I said trev... “A turkey bar isnt cen worthy”.
RIP- Tammy (9/14/08)
brushlessboy16
brushlessboy16's Avatar
10.09.2008, 08:04 AM
psht, the thing is indestructable..
Motor mount will be tweaked when i get home today, a trim and lengthening the mounting slot
Takedown
Takedown's Avatar
10.09.2008, 11:50 AM
What Im saying ben is if you can get the cen to wheelie with the stock diff fluid and not a locked center diff then the turkey bar might be acceptable...
brushlessboy16
10.09.2008, 02:19 PM
ugh. well i will let you know shortly, about to leave school- just have to mount my battery tray then go run :D
trev3813
Dsm needed
trev3813's Avatar
10.09.2008, 03:01 PM
^ Cool, Turkey bar 4EVER lol
brushlessboy16
10.09.2008, 03:23 PM
I have actually decided to strip down the cen and do a full rebuild, should be running tommorow
JThiessen
JThiessen's Avatar
10.09.2008, 03:35 PM
Do your homework first!
10.09.2008, 04:25 PM
brushlessboy16
10.09.2008, 05:04 PM
no homework tonight, and a four day weekend!!!!
yeah yeah i know...
Should be fun- one of my best freinds (eovnu87435ds) just got an evader, so hopefully we can get to gether and bash :D
One thing about the truck- RYAN you never sent me preload spacer, truck almost bottoms out fully loaded
10.09.2008, 05:13 PM
Lol, so does my hyper ST.
Takedown
Takedown's Avatar
10.09.2008, 06:02 PM
As a matter of fact I slapped the heavier springs on their so it wouldnt need the preloaded spacers. Their sitting right on my shelf in a little baggy.
brushlessboy16
10.09.2008, 06:25 PM
gimme
Takedown
Takedown's Avatar
10.09.2008, 07:32 PM
Oh darn they found their way to the garbage can...
brushlessboy16
10.10.2008, 11:17 AM
thats not even funny.
Anyways-
Just did a shakedown run. Truck is solid but somethings need to be tweaked... like the center diff fluid... if i gun it the front wheels do indeed come up. but the tires look like pizza cutters.
Then i had a pinion work itself loose, luckily it stayed on the truck
-Motor only got to 130 degrees geared for 46mph... The fan on the MMM came on alot.(w00t its still alive)*mods- switch removal, teflon washer, custom foam inserts.
- I eventually got used to driving and had to use a light trigger finger.. the truck is very easy to correct in the air.. it does get a little torque roll-probably due to the giant spur gear.
Because of the diff unloading and me trying to keep this set of tires. i never did any speed runs, just a little bashing- the suspension is soo plush.. a little too plush on the rear.
Lost Parts- One kingpin screw
Loose parts- Pinion setscrew, right front wheel nut,
Things to fix- Antenna placement
Krawlin
Got brushless?
Krawlin's Avatar
10.10.2008, 05:50 PM
Sounds great Ben, but do you have some kind of phobia of your camera?! Get us some pictures!!!!
Monster GT Conversion
Tags
cen matrix
