Revo custom chassis
bensf
Revo custom chassis - 10.09.2008, 11:39 PM
I've been thinking about doing something like this for a while and finally got around to draw it up.
I'm thinking about moving the battery down to the lower tray to lower the COG.
Anyone have any tips for me?
10.10.2008, 08:40 AM
1) Measure twice, cut once.
2) Use decent 6061 or higher grade 3mm thick aluminum- you could get away with 2mm thick 7075.
TexasSP
Something, anything, nothing
TexasSP's Avatar
10.10.2008, 10:31 AM
Make a good mock up using cheaper material. Maybe some good plastic type like delrin or a low grade aluminum. No reason to waste expensive AL on the first couple of pieces until you are completely satisfied with the setup.
www.cubicle101.com
brushlessboy16
brushlessboy16's Avatar
10.10.2008, 10:33 AM
invest in a good 90* countersink bit
You will need it :D
bensf
10.10.2008, 06:11 PM
I have some ~1.5 mm aluminum laying around that I was going to use as a mock up. Also does anyone know what would be a good spacer to use inbtween the chassis. I'm thinking something like a maxx bulkhead brace.
TexasSP
TexasSP's Avatar
10.10.2008, 07:57 PM
Check out some of the axial crawler parts. They have some threaded rods that would work well and some assorted lengths.
www.cubicle101.com
10.10.2008, 09:25 PM
These are good to use, you can also get the al radio tray spacers that many 1/8 buggies use. They are often tapped to use m3 bolts, and can be cheap. I remember the ofna ultra sereis uses these, and ofna stuff is usually cheap. Not sure if they will be the correct length though...
bensf
10.10.2008, 09:59 PM
I can always cut/grind to size. How hard is it to tap threads in 6061 and 7075 aluminum?
I'm almost ready to start my mock up out of the 1.5mm stuff.
TexasSP
TexasSP's Avatar
10.10.2008, 10:10 PM
Easy to tap. I think 7075 is slightly easier because of it being harder, it doesn't gum up the tap like 6061 does. In fact if you use 6061, I only recommend hand tapping it. In my opinion it was to easy to chew up using a mill to tap it. Also make sure to use something like tap magic to help.
www.cubicle101.com
10.10.2008, 10:34 PM
6061 is not too bad to tap, but cutting oil for al is a must. I have not tapped too much 7075, but found it harder to do.
I usually use my benchtop drill press, clamp the item in the small vise, and turn the press pulley by hand while feeding the tap into the hole. Perfect cuts everytime, and the vise helps to keep the threads straight and true. Plus I have never broken a tap this way. Eevn a cheap small drill press works great, I am using a small craftsman unit right now.
bensf
10.11.2008, 02:34 PM
Has anyone gotten UHMWP locally? Or delrin or something similar. I've gotten it off of mcmastercarr before, but buying stuff like that online seems like a ripoff because of the shipping.
doo540
10.11.2008, 02:44 PM
Hey bensf
Did you look at the chassis offered by Kershaw Design, he has two aluminum frames, one for e-revo's and one for nitro revos going to electric, might be easier in the long run for you. There is a picture of the nitro conversion on his website.
bensf
10.11.2008, 02:54 PM
Yes I have seen that, but there are a few things that I don't like about it. It has 2 battery trays. 2 servo mounts. The bottom plate doesn't attach to the bulkheads in any way. In my design I attach the bottom plate to the bulkheads, which I think will make it substantially stiffer.
bustitup
10.11.2008, 03:21 PM
nice drawings but my opinion would be not to run one bat on the side like that for balance reasons....like i said my opinion only
a 3.3 chassis can easily be modified to run two batt trays and go with a 3905 tranny and your good to go
check mine out...its a 3906 tranny but you get the idea
and this picture shows a nihm on one side and a lipo on the other side just for battery placement mock up
bensf
10.11.2008, 03:49 PM
I do agree about the battery placement, but I already have a 5s 8Ah battery and I don't want to get a new one. I am currently using a 3racing chassis with a maxx tranny.
