Thread Tools Rating: Thread Rating: 10 votes, 3.60 average. Display Modes
emaxxnitro
emaxxnitro's Avatar
10.19.2008, 06:24 PM
thats a bad *** motor!
808E
lutach
lutach's Avatar
10.19.2008, 06:53 PM
Yes, but 4 and 6 pole motors are taking over and for a good reason.
E-fanatic
Brushless only!
E-fanatic's Avatar
10.19.2008, 07:31 PM
Are the combos going to come with the black motor like the pic or green like the rest of castles motors. I like the black!
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.19.2008, 08:41 PM
I think the ones made for Traxxas will be black and the Castle ones will be green.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
brushlessboy16
brushlessboy16's Avatar
10.19.2008, 09:07 PM
could be, i personally like the black.. green doesnt go well with very much LOL
molak
10.19.2008, 11:07 PM
IŽll really like to see a motor can with heat pipes. Even if they are heavier than a simple heatsink, at least the are pasive devices.
Unsullied_Spy
Unsullied_Spy's Avatar
10.19.2008, 11:19 PM
You shouldn't need heatpipes, water cooling, or even fans though. If your motor is running too hot there are issues in your setup. It could be gearing, binding, poor quality motor, etc. but a proper setup will not overheat. Before the unfortunate frying of my Neu, the hottest I could get it was 145F which is fine considering how long I ran it, how hard I ran it, and it was too high of KV for my application.
brushlessboy16
10.20.2008, 07:06 AM
i got mine to 155 but was geared for 53mph or so..
emaxxnitro
emaxxnitro's Avatar
10.20.2008, 09:17 AM
not if you are running high voltage! 2poles can take high voltage better than 4poles. Now 4 poles are better for 6s and under 2poles are going to have higher rpm
808E
brushlessboy16
10.20.2008, 03:01 PM
rpms causes destruction.. 4 and 6 pole motors make more torque and turn lower rpm. keeping them in below failure point, the added torque allows you to gear to compensate...
He is right multipole motors are better..at high voltage
Pdelcast
Pdelcast's Avatar
10.20.2008, 03:25 PM
Traxxas motors are all black, Castle are black and green.
Patrick del Castillo
President, Principle Engineer
emaxxnitro
emaxxnitro's Avatar
10.20.2008, 06:47 PM
nice! but i already have a 1515 1y so will the ccneu be better or about the same
808E
emaxxnitro
emaxxnitro's Avatar
10.20.2008, 06:50 PM
not if your motor is rated for it! the c50 comp is a 80000 rpm motor. and the 9xl can take up to 8s (my future bl plans)
808E
Pdelcast
Pdelcast's Avatar
10.20.2008, 08:26 PM
I don't know how you can say this. And I have to disagree with you on this as well.
Usually, pole count is determined by rotor diameter, not by voltage. Voltage doesn't really enter into the equations at all -- you can always change windings to make up for pole count difference (for example, a 2 turn 2 pole is the same torque as a 1 turn 4 pole...)
lutach
lutach's Avatar
10.20.2008, 08:31 PM
I also think the 4 pole mentioned by Patrick will still have more torque being it has twice the magnet. Basically a 2 pole would be a 4 cylinder and a 4 pole would be 6 cylinder and 8 pole well would be 8 cylinder. Ever wonder why outrunners have more torque then our popular 4 pole inrunners?
Tags
1515 1y, brushless, castle neu, mamba monster, mmm
