Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
sweetride4me
11.06.2008, 08:14 AM
I'm impressed Lito.... I'm craving brushless after I drove my new supervee 27 brushless boat...
George16
Supermaxx
George16's Avatar
11.06.2008, 10:34 AM
Thanks. Go ahead and start your brushless build. It's fun.
Here's some pictures of the build progress.
Rear extended arms installed:
Suspension installed:
TeknoRC motor mount installed:
1515 1Y/F installed along with the UE 4-shoe clutch and Kyosho 17T narrow clutch bell. The finned version was almost a tight fit. I had to push it in a little bit. I used 4 8mm caphead screws to mount the motor.
I'll be installing the MMM tomorrow night after I finish soldering all the connections. My target is to do the test run this coming weekend.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
TruckBasher
TruckBasher's Avatar
11.06.2008, 10:36 AM
Cant wait for the video Lito
E-Slayer direct drive to diff
George16
Supermaxx
George16's Avatar
11.06.2008, 10:44 AM
I hope my son will go to the track with me or else....... .
I almost forgot I still need the 2S packs I ordered so I can run 4 and 5S on this truck. Right now, I start with a 36T spur and 17T pinion and go from there. If I don't like the temps, I'll go down to 16 or 15T clutch bell.
Revo with OS .18TZ
sweetride4me
11.06.2008, 11:13 AM
Wow that looks great can't wait to see it run... BTW Lito what charger are you using?
11.06.2008, 11:17 AM
Looks great.
George16
Supermaxx
George16's Avatar
Thanks guys.
Chris, I'm using a Hyperion 0610Duo for my charging needs. It's powered by a 25A Pro-peak power supply.
I need to sell my Super brain 977 on fleabay so I can buy more batteries .
Edit-We'll see how long this 4-shoe clutch will last.
Revo with OS .18TZ
BAD 1
11.06.2008, 01:28 PM
Looks GREAT!!!!!!!! I appreciate the play by play action of your pics and your walk through process. Good information. Thank you for sharing and keep up the good work.
Sorry for interfearing with my dum pictures that did not apply to your post.
George16
Supermaxx
George16's Avatar
11.06.2008, 06:41 PM
It's okay. We're all here to share information anyway .
Revo with OS .18TZ
sweetride4me
11.06.2008, 09:51 PM
Any reason you chose the 2.5 chassis over the 3.3??
George16
Supermaxx
George16's Avatar
11.07.2008, 12:38 AM
It's just a spare chassis I was given . I might buy a 3.3 chassis on fleabay if I don't like the balance and how it handles.
Revo with OS .18TZ
thephilonator
WHERE'S MY COOKIE?!
thephilonator's Avatar
11.07.2008, 11:48 PM
well done Lito. 17 days from chassis with almost nothing on it to nearly completed.
i must say though, is there any substantial benefit from using the elecktri-clutch? to me it just looks like extra weight.
"I swear to drunk I'm not God occifer."
George16
Supermaxx
George16's Avatar
11.08.2008, 02:20 AM
Thanks.
I'm not really sure how the elektri-clutch is going to work to be honest with you. Since it came with the conversion kit, I might as well try it . I do have some pinions I can use if I don't like the elektri-clutch.
Revo with OS .18TZ
George16
Supermaxx
George16's Avatar
11.08.2008, 02:44 AM
More update:
I installed the MMM today. I don't like the TeknoRC mounting position so I fabricated my own mount using 3mm aluminum.
Stock on right side, my creation on the left side:
After it was painted.
The holes line up with the rear shock mounts. I used 25mm spacers and 2 40mm caphead screws to mount it in place.
With industrial velcro:
I also lengthened the MMM switch wire:
My biggest concern. The positive bullet connector is too close or either touching the heat sink. I can't install a heat shrink around it.
The MMM temporarily mounted on the truck. The ESC sits lower now instead of being on top of the tranny.
Revo with OS .18TZ
George16
Supermaxx
George16's Avatar
11.08.2008, 09:40 AM
Here's a video on stand. It's running on 3S since I have not received my 2S packs yet. I still have to install the brakes.
Revo with OS .18TZ
