Mamba Max w/ Fiegao 9L - Series Harness? Or what?
rawfuls
roofles.
rawfuls's Avatar
Mamba Max w/ Fiegao 9L - Series Harness? Or what? - 11.08.2008, 06:08 PM
I can't remember correctly.
I believe it's the series harness?
Where, the female deans/connector goes into the male ESC deans/connector, and the female deans/connectors is split into two deans?
Anyone have a good diagram? Or should I just pick one up from like GA?
rawfuls
roofles.
rawfuls's Avatar
11.08.2008, 06:09 PM
Like this?
http://cgi.ebay.com/Great-Planes-SER...3286.m20.l1116
brushlessboy16
brushlessboy16's Avatar
11.08.2008, 06:13 PM
series
parallel
11.08.2008, 06:15 PM
You want to run 2x 2s lipos, do this:
http://scriptasylum.com/rc_speed/_pi...20lvc_1.gif~18
rawfuls
roofles.
rawfuls's Avatar
11.08.2008, 09:59 PM
So I'm looking for the series right?
Does the postive and negative go together.. right?
mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
11.08.2008, 10:05 PM
depends. what batteries do you have?
-mikey09120
rawfuls
roofles.
rawfuls's Avatar
11.08.2008, 10:12 PM
For now, NiMHs, but have some hardcased 5000mAh 2S ones on hand. That I should be testing out sometime tomorrow.
rawfuls
roofles.
rawfuls's Avatar
11.08.2008, 10:44 PM
Also included 3A-5Amp UBEC.
Now, I'm completely new to the brushless world, but what does the UBEC accomplish? And how do I wire it? With the diagram, I'm viewing that I should be splicing it into the ESC's Male Deans?
rawfuls
roofles.
rawfuls's Avatar
11.09.2008, 03:14 AM
anyone?
Unsullied_Spy
Unsullied_Spy's Avatar
11.09.2008, 03:51 AM
pic
Is that what you're looking for?
http://scriptasylum.com/rc_speed/_wiring.html
rawfuls
roofles.
rawfuls's Avatar
11.09.2008, 11:43 AM
Are the series harness the same, even with NiMHs?
and
11.09.2008, 01:31 PM
This is not the Traxxas forum....
Read one of my FAQs, then the tutorials that follow them in the same threads- that will answer all your noob wiring and BEC etc questions in explicit detail
rawfuls
roofles.
rawfuls's Avatar
11.09.2008, 04:39 PM
Too true Neil.
Actually, mikey said that, up above.
The FAQ is just so long :( Fine.
rawfuls
roofles.
rawfuls's Avatar
11.09.2008, 04:44 PM
Actually Neil, since I'm only going to be running the 2S (x2) LiPos, I won't be needing the UBEC, will I?
Of course, if I was running 4S, I would need it.
Or is running 2 lipos in series doubling the cells, thus causing 4S? Or am I just gone stupid.
11.09.2008, 05:20 PM
You dont need to read the whole thing, there are seperate sections relating to the different issues you are asking about.
2 + 2 = 4. Series doubled the voltage, parallel doubles the mah.
You will need:
A UBEC / BEC.
A capacitor equal to 25v 105*C low esr 2000-4000uf.
A series Y-harness for the 2x 2s lipos to be wired together IN SERIES.
Yes, you are stupid, now go away before I fart on your head.
If you skip to the lipo tutorial, it explains what you need to do, as does the BL upgrade section in the FAQs.
Its all good...
