which diff is stronger...
lydiasdad
which diff is stronger... - 11.09.2008, 11:54 AM
The new 3905 e-maxx diff or this http://www.rc-monster.com/proddetail...zerdiff&cat=47 I am needing one for my 1/5 scale e-maxx/baja. I will be running 7s2p a123 with a kb-10l. Thanks.
11.09.2008, 01:51 PM
I would use the 3905 diff with the flm al cup and some sort of al case.
traxxasbasher13
11.10.2008, 12:06 AM
LST diffs. Go here:http://www.rc-monster.com/forum/showthread.php?t=9153 Hope it helps!
blueb8llz
11.10.2008, 01:05 AM
if you use 3905 diffs with the flm 3mm diff cup, theres only one company that makes a AL diff casing, which is golden horizon. heres the cheapest place i found them
http://www.rcplanet.com/ProductDetai...H02584&click=3
11.10.2008, 01:08 AM
Originally Posted by traxxasbasher13 View Post
I did this myself, actually was going to sell the required parts to do the swap, but did not find a suitable front case support to modify to fit the lst case. And I did not feel like making them myself...
TDC57
TDC57's Avatar
11.10.2008, 02:14 AM
If you want to some (bullet proof diffs) get these.. I have them and they are great!!, i been running run them on my GR3 E-Revo on 6-8s for the past 8 months and have had no problems at all with them..
Just a thought..
http://www.rc-monster.com/proddetail...rod=rcmflmrvdf
P.S.
Yes I know you mentioned the 3905 and these are Revo diffs, but hey that’s why there is fabrication..
Nothing!.. Hahahahaaa..
lydiasdad
11.10.2008, 07:17 PM
I don't think you can use the flm cup with the 3905 diffs. the 3905 diffs are basically revo diffs in a case that fits in the maxx bulks. right?
11.10.2008, 07:27 PM
Near the bottom of this page they list a specific 3905 cup with gear. And they have just the cup to work with the stock 2.8mm bolts.
http://www.fastlanemachine.com/Publi...9/Default.aspx
blueb8llz
11.10.2008, 08:58 PM
id get the 3mm screws for the extra $15. let me know if you find another company that makes AL cases other than the golden horizons one that i linked. i think i remember reading someone had to made a few mods to make it fit correctly.
