Is there a way to get rid of the on/off switch on the mm esc and have it still work? -
11.29.2008, 11:12 PM
I am tired of switches breaking, having to soldier new ones, etc... can they be used with out the switch?
Dsm needed
11.29.2008, 11:42 PM
Umm, i have 2 brushed ESC's with no switched, i think its the same, just twist and wrap the wires.
11.29.2008, 11:46 PM
The wires broke right at the board so I just un soldiered the remaining pieces from the board...before I put a battery to it, I wanted to ask
11.29.2008, 11:56 PM
Solder them together :D
11.30.2008, 12:55 AM
You have to solder the two pads together or use a small loop of wire to connect them. Or the mm will not be on.
11.30.2008, 01:47 AM
How on earth are you breaking the switch wires so close to the board anyway?
You must be doing something wrong or have the ESC floating around in your car or positioned in a bad spot.
The switch came loose in my car today, but, nothing happened to it & I was doing backflips.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
11.30.2008, 07:13 AM
I broke the switch wire on my MMM about 1cm from the board. Not sure what went wrong, was going for a jump, left it, lost all response, it glided (crashed) to the ground and was still unresponsive. The switch was double sided taped to the MMM casing so it wasn't really flapping about. It has since been replaced by some solder :)
11.30.2008, 11:08 AM
Right now there is a small dab of soldier on the board where the 2 wires are supposed to be soldiered to, nothing more. So you are saying that if I connect the contact points at the board w/soldier it will work? Or would a small loop of wire connecting them be better.
11.30.2008, 11:23 AM
as long as they are connected the esc will be "on" all the time
11.30.2008, 11:28 AM
That's fine....just didn't want to fry the esc that's all...better to ask and be sure! Thanks for your help
Not having to deal with any more switches will be better also!
11.30.2008, 12:59 PM
Magman- it's solder. No "i". Solder. Pronounced sod-er. What you are referring are the people that are overseas fighting for, well, freedom, I guess. I know, I shouldn't pick on someone for spelling, you just did it 5 times so I know it's not a typo, and I'm trying to save you some embarassing looks when you go to radioshack to buy "soldier"
11.30.2008, 01:05 PM
Thanks...that's what I get for not paying attention to detail...I try hard not to misspell words but, even in going over each response before posting, I still miss things from time to time....thanks for the correction!
11.30.2008, 05:22 PM
Good, as long as you dont pronounce it like some weird frenchman, sort of like "sodiee"
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
