Nick
COOKIES!
Nick's Avatar
11.20.2005, 05:57 PM
Here is an example (as attached). The cup I have is on the right. The cup I need is on the left. Is it possible to get those? If so where from? Would they work on stock outputs?
~ Nick.
coolhandcountry
coolhandcountry's Avatar
11.20.2005, 06:12 PM
I understand what you saying. You want something like the stocksliders. The rd logics take the stock grub screw pin combo. I find the ue cvds have better and bigger grub screws and seem to hold alot better than the others. My ue cups don't seem to come lose.
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.20.2005, 07:13 PM
Ur tired of teh 7xl? I might be interested in it. I got a nemsisi blue 9L motor that i might trade if you want. I gotta test it out first, but i rather have a 7xl, cuz it wont heat up as fast under race conditions.
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.20.2005, 11:45 PM
What drive cups are you using, Nick? I haven't had any troubles with the UE or MIP drive cups, which both use large set screws. I also have Tsais drive cups here, which take the stock pin.
Nick
COOKIES!
Nick's Avatar
11.21.2005, 04:53 AM
I use MIP.
How much are the Tsais cups?
Rdlogics take stocker pins too? I think that would be my best alternative.
~ Nick.
Dafni
Dafni's Avatar
11.21.2005, 06:22 AM
Never had problems with MIP either. Their setscrews work just fine, but when I have the opporunity, I swap the setscrews with some selfmade ones. I just take long setscrews and make them pointy on a lathe. Never did this in quite a while, though.
I have MIP cups in the centerline of my most used truck, un-modified, and never had a problem there.
Nick, just make sure you tighten the set screw on the flat surface of the output shaft.
coolhandcountry
11.21.2005, 09:50 AM
I find that loctite and tightening the screws down good works great. I turn one in until it starts tought the shaft. Tighten the other side up tight then tighten the first side up tight. It puts more even pressure on the cup. Just a suggestion. Hope this helps you out nick.
Nick
COOKIES!
Nick's Avatar
11.21.2005, 12:26 PM
Red or blue loctite?
~ Nick.
Sylvester
Sylvester's Avatar
11.21.2005, 01:28 PM
This also asks me, whats the difference between the two? Or is there no noticable difference and is just colour preference? :p
Serum
Serum's Avatar
11.21.2005, 01:59 PM
Red is to stay, blue is to be removed. I think, Nick, that your output shafts on the diffgears may be damaged. this could be a reason for them to come loose every time.
I use a hex key with a 6" long lever and cranck them all the way down..
Sylvester
Sylvester's Avatar
11.21.2005, 02:05 PM
Ok, thanks for clarifying that for me.:)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Nick
COOKIES!
Nick's Avatar
11.21.2005, 02:48 PM
So I'm guessing I should use blue, if I ever want to see the CVDs apart again? :)
~ Nick.
squeeforever
squeeforever's Avatar
11.21.2005, 08:14 PM
yes, definately use blue. if you use red chances are you will strip the little set screw before you brake it loose.
Sneeck
RC-Monster Custom
Sneeck's Avatar
11.22.2005, 02:12 AM
Just grind 2 small flat erea's down on the shaft where the set screw "set's". Should be fine, no need for a pin that goes thru.
  Send a message via MSN to Sneeck
