squeeforever
squeeforever's Avatar
11.21.2005, 08:33 PM
you can use a bk with the pletty. on the warriors with the 100,000 rpm limit it just can exceed 50,000. i think the micros have a 150,000 rpm limit (please correct me if im wrong) so if would be good up to 75,000 rpms which you would never see with that motor. im not sure what would happen if it did exceed the max though.
-corey
Gustav
Gustav's Avatar
11.21.2005, 08:44 PM
I think the big problem with the shulze(apart from arrogance) is actually the bigmaxx,it just can't handle it reliably and it's the controller recommended with that motor.I don't think it's a coincidence that it's always the 18.97 that snuffs it.I'd like to know how many were running the bigmaxx at the time.
I bought that combo before i found RC-Monster and Serum's hall of shame,i ended up using the controller in a lower stressed application in a stadium truck where it doesn't even get warm.If you sold the 4-pole and got a 2-pole then i think the controller would be alot safer.
MetalMan
MetalMan's Avatar
11.21.2005, 09:00 PM
-corey
I have heard that the BK Warrior controllers aren't really able to run the 4-pole Plettys very well, but this doesn't have anything to do with RPM limits (which I believe you are correct on).
The MicroCar is the one with the 42,000 RPM limit.
Serum
Serum's Avatar
11.22.2005, 01:13 PM
You can not run a 4 pole plettenberg with any bk controller. it is some kind of timing problem that can't/needs to be fixed.. Who needs plettenbergs when there are 2240's and 50's...?
squeeforever
11.23.2005, 01:13 AM
i asked mike a while back if the plettys would work with the warriors and i was told that it should work but the rpm limit would be cut in half. the reason i asked was because of something i saw on the instructions (that make no sense).
