Hyper ST CF Chassis Conversion
Hyper ST CF Chassis Conversion - 12.22.2008, 03:38 PM
Sup guys, as you know I have a BL Hyper ST with a 600XL, MMM and a 6s NeuEnergy lipo. Its ungodly heavy (in a bad way) at 10lb 14oz RTR. IE- time for a diet. Lutach thinks that I could get my truck around 7lb RTR. I will be making a 3mm CF chassis with a hybrid alum front to take care of the kickup. I will also upgrade the truck some along the way with a new DX3S radio system, possibly a better motor, and just fixing the things that need a little love. I will ditch the center diff in lieu of a ofna solid centre with a 51t plastic spur. I will also change the springs and go thru the entire truck, helping it out a bit. I don't have any pictures at the moment because I do not have a hookup cable for my camera. I am getting my milling machine tomorrow (only 363 days later than planned) and will be purchasing the CF sheet shortly thereafter. Thanks for reading everyone and have a great one!
wallot
wallot's Avatar
12.22.2008, 04:00 PM
I dont think that u can get the truck to 7lbs. RTR nitro truggies are 9-10 lbs
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
brushlessboy16
brushlessboy16's Avatar
12.22.2008, 04:03 PM
yah 7lbs if u do a Mr c conversion and make EVERYTHING carbon fiber.. i dont see that getting down to 7lbs with a 6s pack- just wont happen.
maybe as a roller... Im interested in mill work tho :)
12.22.2008, 04:18 PM
It will be as light as Mr. C work. I'm not sure if I'm going to do CF shock towers or not.... I firgured 7lb is a decent number because Lutach got his MBX5T down to 5.5lb RTR with 8s lipos.
12.22.2008, 04:19 PM
About mill work- I will charge:
Cost of material
$15 per hour of work time
brushlessboy16
12.22.2008, 04:30 PM
thats hard to believe...
12.22.2008, 04:33 PM
Nobody is stopping you from asking him.
Ryu James
Ryu James's Avatar
12.22.2008, 04:44 PM
whats up BL RVO,
i am excited to see your project. as you know i am doing the same thing. i tried the chassis first without kickup and it worked pretty good but some adjustments have to be made so i will now be doing a alum and CF fusion for the kickup as you will be doing. thats great that you have a cnc machine. where are you located? i would be willing to pay to have my pieces cnc'd. another member also offered to do this but just wondering if you might be closer to me. i am in utah. closer distance means less time and money for shipping. anyway, here are some pics of how i intend to do mine. btw, still havent weighed mine but the 5mm isnt much lighter, if at all. the 3mm will definitely shed some weight though.
http://www.rc-monster.com/forum/show...t=17104&page=4
chassisfusion2
Jammin SCRT10 Neu 1512 1y
12.22.2008, 05:00 PM
I do not have a CNC, I will be getting a manual mill.
Ryu James
Ryu James's Avatar
12.22.2008, 05:03 PM
how well does it work? where can i buy one? any pics? how much did u pay? i would love to stop using my dremel for milling. lol.
lutach
lutach's Avatar
12.22.2008, 05:04 PM
With 6S 2200 and 2500mAh it's actually close to 7lbs and with 8S 3700mAh it's actually a little over 7.5lbs.
lutach
lutach's Avatar
12.22.2008, 05:05 PM
I hope you will send mine if you use my design . I'm very picky too , it must be perfect .
12.22.2008, 05:08 PM
This is the mill I am getting tomorrow.
http://www.harborfreight.com/cpi/cta...emnumber=33686
Oh ok.
I'm actually not going to use your design, just going with a single battery pack. Only chassis I can compare it to would be Mike's, except mine will be CF and I will have the RX in a different spot.
Ryu James
Ryu James's Avatar
12.22.2008, 07:01 PM
it looks pretty nice but is there a way to move the item you are milling or do you just have to use your hands? if there is a way to clamp down the chassis and then move the entire table in any direction (by turning knobs or something like on a lathe) this will result in much straighter cuts. i know moving it around by hand to mill out an area is tough to keep straight. i will say this though. milling carbon fiber is 100x easier than milling alum. you can see the milling i did on my CF chassis with just my dremel. not super clean but not bad. i tried the same thing on alum and just gave up. a real pain in the ass with a dremel.
chassisfusion1
lutach
lutach's Avatar
12.22.2008, 07:04 PM
Most manual milling machines you can lock one lever and move the direction you want without the other moving. Machines that cnc's CF are very high RPM and uses carbide bits and this is where the high cost comes into play.
