Yet another Gorilla is born
marcus
marcus's Avatar
Yet another Gorilla is born - 01.06.2009, 08:24 PM
I know it's been done before but this is my first Gorilla Build so perhaps you guys can point out any failings in my plan.
It's not however the first T/E-Maxx I've built so it's familiar territory and I still have a bunch of unused stuff hanging around from those earlier builds
I originally started with the of idea using an old "Ebay Special" E-Maxx I'd picked up as a base but in the event this project has gotten way out of hand and ended up being assembled from 95% new parts. I think the only parts that were from a donor truck are some gearbox parts, pillow balls and a couple of hinge pins [gulp]
Rather than build up a full Alloy Shelf Queen (a sickness of mine) I planned to make this project useable from the outset. Alloy has been used exclusively where needed only, diff casings, bulkheads, steering linkages and chassis. The suspension parts remain plastic albeit RPM
This way the truck remains light & nimble but hopefully strong and resistant to the bending & breakages all-alloy vehicles invariably suffer.
So, to battle.............
4-spider HB diffs with Nova buckets, SuperMaxx cups and RCM output shafts should take anything I will throw at them
FLM Hybrids
RPM towers, mounts, arms, knuckles, bumpers, braces & skids
Supermaxx shocks
Seems little point in having two motor mounts if I'm using One motor so
Using the old gear casing as a guide, my trusty hacksaw and Dremel soon had the spare metal in the trash can
Mocked together with dummy gearbox in place to enable me to make centre shaft measurements
George16
Supermaxx
George16's Avatar
01.06.2009, 08:37 PM
Nice-looking build. I actually left the other mounting mount for the 2nd motor because it helps in cooling the motor. It acts as a heatsink.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Looking good.
marcus
marcus's Avatar
01.06.2009, 08:38 PM
Why use just one high torque steering servo when two will fit?
Some modification to the steering linkages and servo heights was called for but it works very well.
Pictured here with one alloy crank and one plastic - second alloy crank in post Grrrr
Radio Box installed between steering servos.
Servo wires run inside boot laces and into box through rubber grommets to clean appearance
Alloy Gear Box casing will stop any meshing issues to to case flex
Ofna 17mm Hexes
Revo ProGraphix body with Mirror Chrome highlights
Waiting on Electronics and a selection of pinions as well as a Robinson slipper.
Got to make up a dogbone for the front centre, should be interesting.......
marcus
marcus's Avatar
01.06.2009, 08:39 PM
I wondered about that but figured the alloy gear casing might sink heat away too.
I'm wondering whether to use the second motor mount point to hang an ESC mount from actually.........
George16
Supermaxx
George16's Avatar
01.06.2009, 08:47 PM
Are you still running a 2 speed inside that transmission?
Revo with OS .18TZ
01.06.2009, 09:09 PM
I dont see how he could really- both servos are on steering duty , so a 3rd mini servo would have to be custom mounted to the rx box or something.
On the steering servo front (this is like watching my own build in many respects- even the thread title is a ripoff ), the hs645mgs arent really all that high torque, so you really do have to run a pair of them in a maxx (150in/oz each or there abouts)- they wont turn my jumbomaxx rubber at at standstill, but with more sensible tires I think they'll do just fine.
Funny, for a minute there I thought you were the guy who bought my modified motor mount I made a year or so ago...
George16
Supermaxx
George16's Avatar
01.06.2009, 09:13 PM
Hey Neil, I still see the shifting arm on that tranny but no servo.
Revo with OS .18TZ
marcus
marcus's Avatar
01.06.2009, 09:34 PM
At the moment it does indeed have the 2-speed internal setup, I will lock it in 2nd gear.
Eventually I'll pick up a Gorilla single speed setup.....
I think the two 645mg's will be fine for my wheel/tire choice. Agreed they aren't the most powerful but I like them and have good experience with them reliability-wise.
emaxx101
emaxx101's Avatar
01.06.2009, 09:50 PM
i run one of those 645's on my maxx and with mgt tires it turns them no problem. What kind of tires are you going to be running?
marcus
marcus's Avatar
01.06.2009, 10:11 PM
Wabash wheels with 40 series Bowties
emaxx101
emaxx101's Avatar
01.06.2009, 10:21 PM
well you dont have any trouble turning then.
TDC57
TDC57's Avatar
01.07.2009, 02:42 AM
Hey Nice build SIR..
My two cents!..
Loss the 3906 trans (I do like the polished look!) and either have MetalMan fab you up mounts for the 3905 or Yes get the FLM trans.. I like the attention to detail.. Very clean.. Now go it dirty! and show us!.. LOL.LOL..
Nice build Marcus..
You may also need to do this with the FLM...
http://www.rc-monster.com/forum/showthread.php?t=11589
If you have any issues let me, I'll make you one..
Have a great one..
Shaun.
Nothing!.. Hahahahaaa..
Gee
A Horse's Ass
Gee's Avatar
01.07.2009, 02:55 AM
Shaun, if I didn't go to the john a couple of minutes ago. I could of got my post in before you. Seem like you a always get your post in before me and were in the same time zone.
Another Gorilla is always a joyous occasion. Time to celebrate! I like the clean look of the servo box and boot straps. Nice job. Where'd you get you tranny case? It doesn't have a FLM look to it.
TDC57
TDC57's Avatar
01.07.2009, 03:08 AM
Great minds do think alike!.. But your a far better Man than I..
It's only 11:00 pm for me; it got to be pushing 1:00 am for you! + It’s 62 degrees out side for me, YOU, your probably freezing your ASS off..
All and all = you’re the better MAN..
Have a great one..
P.S.
Sorry for jacking the thread.. I’ll stop..
