01.10.2009, 01:20 AM
Its 3/16 kydex plastic, was maybe 10 bucks for a 24x18 sheet. Its easy to bend the stuff with a plumbers torch and some patience- all the dark marks you see are burn marks
Cool, thanks.
brushlessboy16
brushlessboy16's Avatar
01.10.2009, 08:58 PM
Ran the truck today at school(robotics) ran pretty well aside from a few things- the new spur gear is louder then the humongous 66t,My motor mount came loose and almost totaled my pinion(my fault-loctite time). The only real problem was the front walls of both battery trays broke out- they were held in by 2 little m3 coarse screws. both screws pulled out when i came off a jump and landed nose first...perpendicular to the ground. 2 part epoxy should do a better job no?
The truck turns a hell of alot better with the 0 offset wheels and the weight better distributed.. Now I just need to get some bent tie rod ends to clear the wheels and get my steering throw back
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
01.10.2009, 09:09 PM
ya. we both kinda failed today at school... I slid off a curb i was riding parallel to, and hit the corner of the curb with only the front left arm, and did cartwheels 5 feet in the air, and tumbled all the way into the building 25 ft away. nothing broke that time. then i backed into the curb at a slow slow speed and the front bumper shattered
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
trev3813
Dsm needed
trev3813's Avatar
01.10.2009, 09:15 PM
Well, i jumped a dirt pile with my revo so there
Seriousness, sounds like alot of fun.
brushlessboy16
01.10.2009, 09:51 PM
I jumped my freind dylan.
01.10.2009, 09:59 PM
I waited some more for my nomadio system. Hasn't paid off yet.
brushlessboy16
01.10.2009, 10:06 PM
Im still waiting for my second M8.
Our(mike and I) back up radio is a POS 75mhz fm with some dead rechargable Nicads... it decides when it wants to work and only has about 50 foot range. it sucks
01.10.2009, 10:17 PM
JesseV
01.13.2009, 03:04 PM
I just realized my matrix is a mess. Hong Nor rear hub carriers, hobao front hub carriers (metal both), hobao rear and center diff, torsen front diff. Other parts are Cen factory race parts. Hmm what next, maybe the Inferno spur? :P
brushlessboy16
01.13.2009, 07:31 PM
More voltage
Takedown
WARNING: May become violent.
Takedown's Avatar
01.13.2009, 09:03 PM
More voltage
You need another RCM 2s pack ben.
RIP- Tammy (9/14/08)
01.13.2009, 10:12 PM
This thread is still going? I stayed out of this thread for accusations of spamming by someone who will remain nameless. (BrushlessBoy16)
JesseV
01.14.2009, 08:49 AM
More voltage
Well I could use 5s but charging times would increase, and I already charge 1,5 hours these 4s batteries.
50W Imax B5 you see.. Voltage goes up, amps go down.
brushlessboy16
01.14.2009, 08:56 AM
I feel your pain. i have the same charger.
Takedown
Takedown's Avatar
01.14.2009, 05:56 PM
Get a name brand charger that put out the proper wattage.
Tags
cen matrix
