01.11.2009, 03:47 PM
FWIW, the FLM CVDs work quite well so far. And Mike has them in stock (or did when I got mine a few weeks ago).
Robert
01.11.2009, 03:49 PM
I just caught your post on on the traxxas board. :) I've lossened the slipper a bunch and that seems to be keeping it together but I'd rather have all that power to the wheels.
I notice you seem to cruise through that grass. :) Stock tires?
skellyo
skellyo's Avatar
01.11.2009, 03:53 PM
Pro-Line Switch tires on the Pro-Line Epic beadlocks
Robert
01.11.2009, 03:59 PM
Whats your opinion on the Pro-Line Epic beadlocks? I haven't heard to many positives... How many runs do you have with them?
phildogg
phildogg's Avatar
01.11.2009, 04:16 PM
I've got a question for all that have these trucks.. How do they compare to the rustler? I know they look wider just wondering.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
skellyo
skellyo's Avatar
01.11.2009, 04:20 PM
I've run them through a pack and a half on 4S with no issues. If I'm not slinging the tire off with the power I'm running, I'd say they're pretty good. However, I've put a half dozen or more sets of beadlocks together. For those that haven't done it before, it isn't hard to screw it up and seat the bead incorrectly.
skellyo
skellyo's Avatar
01.11.2009, 04:21 PM
phil
I actually find it much more fun to drive than the Rustler. It's longer, but it's about the same width as the Rustler.
Robert
01.11.2009, 04:28 PM
How is the hex, does it look decently strong? I'm debating a pair hence the twenty questions.
skellyo
skellyo's Avatar
01.11.2009, 04:37 PM
Looked pretty good to me. Like I said, I've had no problems...and you can see the kind of torture mine has gone through.
Robert
01.11.2009, 04:44 PM
I'll have to get me a set then. I appreciate the input. :)
Robert
01.11.2009, 04:48 PM
phil
I don't have a rustler but I parted out my emaxx for funds for t a slash. Seems to be less fragile. That could be a result of it being a simpler vehicle. ie less parts. I like mine and am happy with the purchase.
drkdgglr
01.12.2009, 05:45 PM
I'm just gonna live with the crazy diff unloading until there is a real solution.
Don't know if you've seen this one yet: http://www.miponline.com/MIP/News/En...missions!.html
and this one:
http://www.miponline.com/MIP/News/En..._Screws!_.html
01.12.2009, 07:22 PM
Originally Posted by drkdgglr View Post
Yeah, I saw that, but I've never been much of a fan of ball diffs. So, I'll just wait until a real diff comes out (if ever).
And I already got the FLM CVDs and they seem to be holding up well so far. They do use set screws to hold the cross pin in place, but also use a metal spring clip to help in case the pin gets loose.
drkdgglr
01.13.2009, 03:55 AM
I don't like ball diffs either. But this one seems easy to adjust and it's probably lighter than an oil filled gear diff. Does look like the gear is plastic though.
skellyo
skellyo's Avatar
01.20.2009, 02:04 PM
Another follow-up:
I took the Slash out again this weekend for some bashing. I replaced a popped yoke on one of my sliders with the slider from my other Slash. It held together just fine for me this weekend. I really had no major issues at all except this damn thing is too fast to run WOT on bumpy ground. The only other minor observation is that the beads on the Switch tires seem to be trying to pull out of the beadlocks. They just look like they're not aligned as well as I had originally mounted them. I believe that removing the tires and taping them should cure this issue in the future. It may also help make the truck more driveable without the rears becoming pizza cutters on every WOT burst.
Overall, the truck is holding up well to the power. I am definitely interested in picking up the new RPM rear bumper mount when it's available. I'm hoping that will keep it from popping off the edges of the chassis like it does with every roll over now.
