tntpower
01.06.2009, 10:18 PM
Got mine too, here's some pics vs mamba max:
hyperasus
hyperasus's Avatar
01.06.2009, 11:37 PM
Is that a 60mm fan?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.07.2009, 06:29 PM
Originally Posted by e-mike View Post
CRAP!!!!!!!!!i can't apply a very low trottle,,,a big cogging appear at mid trottle and my motor come really hot!!!!!!!i try every setting as possible ans nothing to do....not smooth like a mmm... o yes....
my set-up e-maxx geared 24/62,1515 1500kv 6 cell lipo
That is curious because we had similar issues trying to run an outrunner off that same esc. We actually fried the outrunner. It was working fine on another esc and then on that one smoke.
e-mike
e-mike's Avatar
01.07.2009, 06:36 PM
i just hope that we are the only guy's who have this issue....so i shipped the bad unit today for a replacement.....but my friend had one(150amp)and it un flawlesslyso i put it back a mmm in my truck
D8t on juice!!
himalaya
himalaya's Avatar
01.07.2009, 11:44 PM
e-mike, I found your MMM has motor wires soldered directly to the board, does it come that way or you mod it?
Mine has battery wires soldered and femail bullets for motor.
....What a Blue Sky....
e-mike
e-mike's Avatar
01.08.2009, 06:20 AM
normal its a mmmv1
D8t on juice!!
florianz
01.08.2009, 08:28 AM
what pwm-setting did you try? i experienced that w. a higher pwm coggin disappears, just like timing. first put the pwm higher, then try different timings, I use eg. 7deg. for a two pole, as long temp. is ok. The cables/wires aren't too long?
what I've read about the small ezruns it seems that at least these esc's are quite ok.
I dunno if that helps, just a try.
I like the three big 1000er caps, that looks solid. size DOES matter...
hailmick
01.08.2009, 08:52 AM
have you tried a 2 pole motor yet ill assume you used a 4 pole when you had the problem
e-mike
e-mike's Avatar
01.08.2009, 06:26 PM
i try a lot of thing,,3 or 4 cell lipo,other motor(feigao and a 1515 2,5d),,ive played with the timing,change the receiver and the transmetter,so nothing to do the esc cog at mid trottle and mu motor come hot really fast
D8t on juice!!
timaneli
01.09.2009, 12:25 PM
did you take off the green ring of the esc that come around the receiver plug of the esc??
donīt do it...
this ring is like a magnet to prevent magnetic interferences on the car...
brushless motors produces alot of magnetic field and mine 150a hobbywing was doing that until i put that green ring with the wire around it again..
regards
you are what you race!!
cheesecake
01.12.2009, 01:56 AM
did you buy the program card with it
molak
01.12.2009, 04:39 AM
are you serious about spending 245 in that combo instead of buying a MMM combo for 260??
tntpower
01.18.2009, 05:14 PM
I have tried mine today on my EIGHT-T, not bad but not as smooth as the MMM.
e-mike
e-mike's Avatar
01.18.2009, 05:22 PM
jle savait que tu dirais ca
D8t on juice!!
tntpower
01.18.2009, 05:34 PM
Here is my set-up on my prog card for the hobbywing 150A:
1-1(forward with brake)
2-4( 15% drag brake)
3-5 (5S lipo)
4-4 (Punch control)
5-2 (brake force 50%)
6-1( not applicable for me)
7-1( drag brake force)
8-2(9%neutral range)
9-3(7.5% timing)
10-1(brushless motor)
11-1(overheat protection enable)
