Is Maxamps any better now?
Electric Eel
Is Maxamps any better now? - 01.16.2009, 07:36 AM
Not had much luck with Maxamps packs in the past, but I was wondering if their new line of 30C and 35C packs are accurately rated? Anyone tried these higher C packs yet?
George16
Supermaxx
George16's Avatar
01.16.2009, 09:18 AM
I have no experience with Maxamps but based on other choices of batteries out there such as PQ, TP, Zippy, Neu, just to name a few, I would just play it safe and buy one of these brands. I'm using PQ and Neu batteries and they have never let me down.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
starscream
RC-Monster TQ
starscream's Avatar
01.16.2009, 10:06 AM
Without having any experience with these batteries its impossible to say how they fair, especially if we do not know who the manufacturer of the cells are.
The prices of these packs seem pretty comparable to most other lipo's so I'd say, for those prices, they'd better perform up to par.
Ha Ha
George16
Supermaxx
George16's Avatar
01.16.2009, 10:12 AM
Give those Maxamps a try and post your findings here.
Revo with OS .18TZ
asheck
01.16.2009, 10:14 AM
http://www.nitrokillers.com/showthread.php?t=1527 Here is there own graph of there 35c 4200.It's still weaker then they are claiming.It's rated at 147amps for 4200.It took 120 amps for 3500.Thats just a single cell,with cooling.In pack form it's probably a 4000mah 25c .Way better then the old ones,but still not accurately rated.
01.16.2009, 10:47 AM
I'd bet they still have the puffing issues the older ones did.
sikeston34m
sikeston34m's Avatar
01.16.2009, 11:25 AM
It was holding 3.1 volts for about 25% of the discharge cycle?
A 35C rating? This graph isn't even a 30C discharge.
This graph shows an overworked cell trying to keep up IMO.
Companies that over-rate their cells say, "OK here's what it will do" falsely. Then the consumer believing it will perform as stated, puts the pack in the high discharge device and runs it as such.
Then puffing occurs.
There should be a standard for the "C" rating for a given pack. Controlled conditions and a rule that says "For a given C rating the pack must hold at least "X" volts per cell for 75% of the discharge cycle and come out no hotter than "X"
I'm looking at a different brand discharge graph here for a 3500mah rated at 30C.
At a 33C load (115.5 amps), it maintains a cell voltage of 3.3 volts for 75% of the discharge cycle. It still dumps 90% of its capacity before hitting 3.0 volts per cell.
A little under rating can be a good thing.
01.16.2009, 11:31 AM
...There should be a standard for the "C" rating for a given pack. Controlled conditions and a rule that says "For a given C rating the pack must hold at least "X" volts per cell for 75% of the discharge cycle and come out no hotter than "X"....
I TOTALLY agree! There was a thread about this very subject a while back. There is no standard so makers are free to say whatever they want as long as they can justify it later on in some fine print.
And, to lend credibility to any claims, all testing/rating should be done by a thrid party.
asheck
01.16.2009, 11:41 AM
Maybe someone on here knows.How did the c ratings come to be used as the standard?Why do they not just use amps?I think it would make our lives so much easier if they said ,100amps constant for 5000mah,before hitting a 3.2volt cutoff.
azjc
01.16.2009, 02:02 PM
I have run thier packs before and I will never give them a second chance, I buy either FPs or Zippys. I am interested in the new EON line that FP has, they are supposed to have twice the power and come in a lighter package.....we'll see how that turns out
Takedown
WARNING: May become violent.
Takedown's Avatar
01.16.2009, 02:07 PM
Ive owned a couple maxamps packs when I was a newb to lipo. I used two 5000mah 2s from them. I have to say they worked pretty good. No offense to what you guys have said against them but my one issue with them is prices. For the price of maxamps just go with the trusted names such as thunderpower, flightpower, neu energy, True RC, enerland, polyquest etc...
RIP- Tammy (9/14/08)
sikeston34m
01.16.2009, 02:28 PM
I believe this is because they want us to understand a couple of things.
Amperage output is affected by capacity for a given "class" or C rating.
A 20C 4000mah pack will put out 80 amps continous where as a 10C pack will put out half of that. You can play with the numbers but the formula remains the same.
To obtain a higher C rating, manufacturers use a greater anode/cathode material to Electrolyte ratio. This is why the higher the c rating, the more they weigh for the same capacity.
It's the use of more Anode/Cathode material in the higher C cells that increases the cost.
I believe most manufacturers don't falsely rate their cells. This is their reputation. But............then the product gets passed to the retailer. It then gets "labeled".
I can just imagine some thoughts like:
Most users won't push these that hard anyway.
The RC Electric setups on the market can't handle more than these put out.
If we charge more, the added profits will cover warranty claims for those that do push them. It's only gonna be a small percentage, plus we can blame it on their setup and suggest larger more expensive packs that we carry. More Sales! It's a win-win.
In the beginning of the "transition" from Nimh to Lipo in the RC Industry, I believe this was pretty easy to get away with.
It's getting tougher, as the market competition increases. The average prices are dropping and the cells are getting better.
redshift
RC-Monster Square Tube
redshift's Avatar
01.16.2009, 04:36 PM
You have to wonder what kind of backroom deals were made for that to happen, maybe only MA employees were polled, I have a picture in my head much like the ROAR-Novak bedfellow situation. Maybe it was the flames on the label that wooed em... people just love image don't ya know.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.16.2009, 06:22 PM
2 or 3s in a 2wd stadium truck such as a Rustler and MA should be fine. In a MT/Truggy 4s will not do! I had 2x 6000mah 2s packs that I ran in series in my E-Revo. They didn't puff but they went WAY out of balance. I had the warranty on them and after finally getting put in touch with the right person I was taken care of better than I hoped. I expected 2 replacement packs whick I would have immedietlly sold. Instead I was offered what I wanted. I wound up with a 2s and a 3s 5000mah pack so I can run them as 5s in my E-REVO with a 1515 2.5d. So far they have done well. I don't have many runs on them but the performance seems to be pretty close to my Neus and the temps where right on par with the Neus. When the weather gets better I will thouroughly abuse these cells and report my findings. One thing that no one can argue about with MA is at least there packs fit a standard tray! That is part of what has made them so succesful.
asheck
01.16.2009, 06:27 PM
Thats true.They are also a well built pack.I think there turd polishing works on most.
